Heatgunning inside fender well plastic
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Methadras, Dec 12, 2018.
  1. Dec 12, 2018 at 11:19 AM
    Methadras
    Methadras [OP] Well-Known Member
    South DFW, TX
    2021 White TRD Sport 2WD
    Fox 2.0 Lift, JLA Uppers, Dual battery setup, ARB-Double Barrel compressor, CBI skidplates, CBI Covert bumper, Winch, various light setups.
    Hey guys,
    So I have Wildpeaks and I had some caster adjustments made to potentially avoid a CMC (for now) and I realize that I'm hitting the front plastic of the inside of the fender well and there is some rubbing in a compound wheel turn/compression situation like hitting a dip while turning, etc.
    I can clearly see where I'm rubbing and it's a protrusion in the plastic of the fender well. Not sure why Toyota contour these things the way they do with nothing behind them. So what I was thinking of doing was putting either taking the plastic inner liner out and heat gunning it to soften the material and shape it so that it's not longer a protrusion. I just don't want to cut if I can avoid it.
    Has anyone heat gun shaped their fender liner plastic? Curious for any tips before I do it. Here's a picture for reference.
    Truck norris and sierra141 like this.
  2. Dec 12, 2018 at 12:58 PM
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    I tried and failed miserably. It pushed and and stayed hntil it cooled then popped back out. Not sure i heated it enough and never tried again. .
    Truck norris likes this.
  3. Dec 12, 2018 at 1:02 PM
    Methadras
    South DFW, TX
    Ah, okay, that's a great pro tip. I think I'll try to hold the shape until it fully cools and see if it pops.
  4. Dec 12, 2018 at 1:07 PM
    aaen
    Northern Alberta
    In know its doable, I just couldnt be bithered retrying
  5. Dec 12, 2018 at 3:40 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
  6. Dec 12, 2018 at 3:49 PM
    Methadras
    South DFW, TX
    Yeah, I hear he's a good dude. LOL.
    Thanks man. Informative. I'm going to do it with the tires off and with a larger rounded shape so I can get in there and hold it with my leveraged weight.
  7. Dec 12, 2018 at 3:50 PM
    pop.tremuloides
    pop.tremuloides Well-Known Member
    Colorado
    2019 TRD OR DCSB
    DBACK HD, Armor, SP9100, lights...etc
    Wow...that guy is awesome! :cheers:
    Nice video Rob.....headed over to Youtube to subscribe....well done!
    PS...nice truck!
    Rob Daman likes this.
  8. Dec 12, 2018 at 4:00 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    I did it with the heat gun, but it's the pinchweld where I rub on.
    Methadras[OP] and Truck norris like this.
  9. Dec 12, 2018 at 4:01 PM
    Rob Daman
    Rob
    So Cal
    17 OR 6MT
    a lot
    Glad to help. You could use a bat or rolled newspaper/magazine for more surface area.
    Rob appreciates it very much:thumbsup:
  10. Dec 12, 2018 at 4:43 PM
    Rob Daman
    Rob
    So Cal
    17 OR 6MT
    a lot
    I think you're going to be closer to CMC territory with the bigger tire. There's a vid too for that :thumbsup:
    In the same vid below we show how to treat the pinch weld.
    https://youtu.be/Oz0hY4upXA4
  11. Dec 12, 2018 at 5:22 PM
    pop.tremuloides
    Colorado
    2019 TRD OR DCSB
    Love the "Sad Panda" in the video!
  12. Dec 12, 2018 at 6:52 PM
    Methadras
    South DFW, TX
    Start hammering. That's what I did. No more problems.
    Rob Daman and tcjacado like this.
  13. Dec 13, 2018 at 8:49 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    Yeah, so far no rubbing on the cab mount. I can see exactly where it's rubbing from where the paint is gone but I have CMC plates in my garage anyway because I plan on going to 35s later. Did you hit the pinch weld with a rubberizer afterwards? Keep up the good work on your vids Rob!
    Rob Daman[QUOTED] likes this.
  14. Dec 13, 2018 at 9:36 AM
    Rob Daman
    Rob
    So Cal
    17 OR 6MT
    a lot
    35s going to be trimming a lot. I went with -20 offset wheels on my 33s and ended up using a jigsaw to trim more. I think I finally got it.
    For the pinch weld I applied silicone along the cuts then sprayed with undercoat.
    Thanks for watching my YouTube channel. :thumbsup:
    rlx02[QUOTED] likes this.
  15. Dec 20, 2018 at 3:50 PM
    Methadras
    South DFW, TX
    Rubbing is now coming from hitting the tips of the fender undersides. Cutting this weekend, but not by much. Wish someone made a new inner fender well for bigger tire/wheel sets.
