Heating/AC vent problem
Discussion in 'Technical Chat' started by Stoneguy, Jan 23, 2013.
  1. Jan 23, 2013 at 11:02 AM
    Stoneguy
    Stoneguy [OP] New Member
    Macon, Ga
    2011 TRD Sport 4x4
    K&N air intake, in-track auto vent shades, wet okole camo seat covers, westin nerf bars, tinted windows
    Could use some help here. I have a 2011 tacoma TRD sport 4x4 with only about 20,000 miles. Yesterday I started it up and the only place the heat or ac will blow from is the defrost vents. It gets hot air and cold air but only from the defroster. Also the recirculation switch stopped working as well. Had the same problem with an old F250 but it was a vacuum line, easy fix. Any help would be much appreciated. Thanks.
  2. Jan 23, 2013 at 3:45 PM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Under warranty I would think, let Toyota figure it out.
    Jikm
  3. Jan 24, 2013 at 8:01 AM
    BamaToy1997
    Bill
    Navarre, FL
    It should be under warranty as mentioned, however as far as the failure itself, it could be several things. Electronic HVAC systems default to defrost if there is a failure in the system. There would be a code stored in the HVAC module that will lead to what the problem is.
