Heating shop/garage
Discussion in 'Garage / Workshop' started by Poorboyota26, Nov 27, 2019.
  1. Nov 27, 2019 at 1:44 PM
    Poorboyota26
    Poorboyota26 [OP] Well-Known Member
    Kevin
    Frisco, CO
    Your standard farm truck
    3" Lift, Rock sliders, Winch, 32's, 4.88's
    What is everyone doing for heat?
    I am in the middle of building a waste oil heater and was curious what everyone else is doing.
    wilcam47 likes this.
  2. Nov 27, 2019 at 1:50 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    My shop has central ac/heat. The heat is electric. The HVAC is the unit that was on the house. The previous owner upgraded the house hvac and had the old system installed in the shop.
    Poorboyota26[OP] likes this.
  3. Nov 29, 2019 at 10:30 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    All types of heat methods I can go Wood waste oil propane and oil hot air.
    The waste oil to just get some benefit from the used oil
    Just depends if I am bringing Cold vehicles in or out..
    Being well insulated helps then it does not really get cold here seldom below zero for days on end
  4. Nov 29, 2019 at 2:59 PM
    Poorboyota26
    Kevin
    Frisco, CO
    Im in the middle of building a waste oil heater but i was hoping to not have to use forced air and get a good clean burn. I have a 8" sched 40 pipe for the burn chamber. Small but i didn't want to have a giant water heater type. I rent my house and it has a 30x22 garage. No insulation. So i don't want to spend the money on insulating it as my land lord won't reimburse. I did insulate the tin garage door as that was the biggest offender. Gotta figure out how to exhaust the heater too.
    Just looking for ideas.
  5. Nov 29, 2019 at 3:06 PM
    ajm
    ajm Well-Known Member
    Anthony
    AZ
    1996 4x4
    When I lived in the midwest I used a wood stove- a 50 gallon drum with stove kit. That thing would keep my uninsulated garage plenty warm. But I had unlimited free wood, just had to go cut and split it. Nothing like a wood stove in my opinion.
  6. Nov 29, 2019 at 5:21 PM
    dofartshavelumps
    dofartshavelumps Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    radiant. very warm water through the slab.
    koditten likes this.
  7. Nov 29, 2019 at 5:23 PM
    1992SR5V6
    1992SR5V6 Well-Known Member
    2018 TRD Sport 4x4 Cement
    Bolt on only...
    I've tried to insulate as well as I good, and heat to the mid 40's with electric baseboard. Perfect for working in a sweatshirt and not that expensive. It's a shop, so not used as a garage, the overhead door stays closed.
  8. Nov 29, 2019 at 5:28 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I'm going to be doing hydronic radiant slab heat with a woodstove for back up
  9. Nov 29, 2019 at 5:41 PM
    dofartshavelumps
    NH
    Is this a garage or workshop? Just asking because when I built a 22x24 barn at my last house the building inspector told me they frown upon wood stoves in spaces where fuel/vehicles will be stored and told me to make sure it is installed on a raised platform. Not sure if that is because volatile gasses are heavy and sink to the ground? Probably isn't an issue.
    PzTank likes this.
  10. Nov 29, 2019 at 5:42 PM
    Tape
    Tape Well-Known Member
    Tape
    2019 Super White OR
    WOOD
  11. Nov 29, 2019 at 10:54 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Next year I plan on putting an electric heater in my garage.
  12. Nov 30, 2019 at 12:29 AM
    OZ-T
    Peter North
    British Columbia
    workshop / storage building , not for vehicles
  13. Nov 30, 2019 at 12:35 AM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    Building Inspector... Lol
    Gus87, det107 and Wyoming09 like this.
  14. Nov 30, 2019 at 4:35 AM
    dofartshavelumps
    NH
    When you live on a small lot and have nosey neighbors its either that or move. Eventually I moved.
    G.T. and PzTank like this.
  15. Nov 30, 2019 at 7:23 AM
    OZ-T
    Peter North
    British Columbia
    building to minimum code requirement is a pretty low bar to get over
  16. Nov 30, 2019 at 7:35 AM
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    I have a 1200 sq ft garage with 13ft ceilings. Use hydronic in floor heating it’s very efficient. IF you decide to use a solid fuel stove in a garage be 1000% sure your insurance will cover you. Actual fire in a garage (with gasoline) is a pretty dangerous combo. You want to at least be sure your covered.
    shakerhood likes this.
  17. Dec 1, 2019 at 10:54 AM
    ralfnjan
    ralfnjan Well-Known Member
    You're
    :canada:
  18. Dec 2, 2019 at 1:00 PM
    Poorboyota26
    Kevin
    Frisco, CO
    Thank you all for the info!
    It's a Rental so my options are limited.
    It is a garage so we are in and out every day. It would be just for heating when working on projects.
    Radiant heat would be the only way to go if I were building a shop. We had radiant heat in the shop on the farm and it was the best ever! no cold concrete when working on implements in the winter. the tractors were always easy to start and everything that would lay on the floor never got cold or gelled up.
    my waste oil heater will have wood option. I am thinking of putting it outside in the yard and water lines through the sophet to a radiator and fan. that might be the least impactful to the garage. I wouldn't have to cut a hole in the roof and if there was a spill or something happened, it would be outside. I don't have a chord of wood to burn though. so that would be another expense.
  19. Dec 16, 2019 at 7:25 PM
    RyanJay11
    RyanJay11 Well-Known Member
    Missouri
    09 TRD 4x4
    I have a Pro Fusion EH-4604 mounted on the ceiling in my 1.75 car garage. It runs on 240V.
    It worked for around 5 years, until this past weekend. I took it apart this evening and fixed it. One of the connections came loose. It's back like new.
    I think I gave $150+ for it. They are dirt cheap now. Northern Tool has them for $90.
    BuddyS and shakerhood like this.
  20. Dec 16, 2019 at 7:39 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Rental changes things.
    If you have natural gas, the math for NG works out to just about the same for burning wood if the wood is "free".
    After figuring out time, chain saws, hauling, stacking, fireplace maintenance and other things, a natural gas unit heater will win. Even with unit heaters not being remotely efficient, gas is only slightly behind in $ spent for heat.
    I have a wood burning fireplace in my shop. It hasn't been lit in 3 years. The gas is much more user friendly.
    My insurance company didn't care that I had a solid fuel heat source, they only checked to if it was Underwriter listed. My insurance cost didn't increase after the inspection, they actually decreased.
