heating the back for camping
Discussion in '1st Gen. Tacomas (1995-2004)' started by eunger, Sep 10, 2010.
  1. Sep 13, 2010 at 7:47 PM
    TallyCast
    TallyCast Well-Known Member
    Dave
    Tallahassee
    '11 Tacoma, 99 Tacoma
    I'd consider gluing aluminum bubble wrap insulation (the kind used for HVAC work) to the inside of the topper. Use headliner cement and if you want to get fancy, you can put some sort of light carpet over the insulation. Some sort of foam in the bed will keep the ground cold out.
    Someone already mentioned the low O2 cutoff heaters. I suspect that with insulation, it will be so warm that you'll want to crack a window.
  2. Sep 13, 2010 at 7:52 PM
    TallyCast
    Dave
    Tallahassee
    Get a deep cycle battery. Connect it in parallel with your vehicle battery. Have a fuse and a diode in the circuit between the two batteries to prevent fires or discharging the starting battery. Plug the heater into the deep cycle battery.
  3. Sep 14, 2010 at 1:09 PM
    David S
    David S Well-Known Member
    sunny Denver, CO
    2012 FJ 6MT
    Here is an interesting report to read about those propane heaters:
    http://www.cpsc.gov/library/foia/foia05/os/co03.pdf
    They do not use a flame, there is a catalytic reaction between the propane and oxygen in the air. However, after reading the report, I wouldn't feel comfortable using it in an enclosed space. The main reason being that it uses up a substantial amount of oxygen and also sends a lot of unburned propane into the air. Not really any better than filling the air full of CO.
    What I would like to use is some sort of a miniature hot water heater with a circulator pump built into it. Set it outside to heat the water, run some water tubing along the bed and you have a nice warm radiant heating system. Unfortunately, that still requires a battery for the circulator pump.
    Maybe an electric blanket powered by a deep cycle marine battery? Will have to run some calculations to see if the batter would last long enough.
    Sure, I have a 0 degree sleeping bag, but when it's 0 degrees, windy and snowing outside, it sure would be nice to have some heat.
  4. Sep 14, 2010 at 1:14 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    If it helps a twin sized electric blanket runs off the 400w plug in the bed but not the 100w when it's in gear.
  5. Sep 14, 2010 at 1:39 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    12v electric blanket and bring along a second battery. You need to figure out a charging method though. Dual battery setup with isolation independent batter with a solar panel loads of options to charge that sucker.
  6. Sep 14, 2010 at 1:46 PM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    This is something that I have been toying with too. For short trips Coleman makes a wall charging emergency car jump battery that will run an electric blanket for a couple nights. Long term I think I am going to run a separate battery to the bed to run a electric blanket and maybe a small heater like the one from harbor freight, and maybe if its possible rig a recharging mechanism from the engine.
  7. Sep 14, 2010 at 1:47 PM
    Jason'sLawnCare
    I just got a duracell power pack. It has a 400w inverter but I believe they make one with 600w. In the instruction manual it says the jumper cables can be used to extend the length of the battery. It charges with the cig lighter so you can charge as your car goes. With a decent battery plus the battery in the power pack it should last a while.
  8. Sep 14, 2010 at 2:04 PM
    sierrahsky
    sierrahsky Expedition Style
    I do a bunch of Truck Camping up here in tahoe ( 6500 + feet depending on trip ) and I have found that an air mattress that stays between wheel wells, a camper shell or a low tarp ( I used just a bivy sack the first time and during a storm used a tarp & bivy ), and a 20 degree sleeping bag with a simple liner did me just fine. I experienced sub 20 degree temps due to wind and had a ton of snow around the truck in the morning. If you keep space open in the truck it will effectively create a cold well ( first thing they teach in the army or survival training ) and will keep the temp + by at least 10 degrees.
    * Also a friend of mine who has a tundra and does a bunch of hunting up in alaska and wyoming said that popping open the slider window and running the heater in his truck on high on defrost for about 30 minutes was enough to give him a nice temp before bed and held ok through the night.
  9. Sep 14, 2010 at 2:21 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Get a Bedrug for insulation. You don't have to do the whole box ... they sell the bed portion by itself. It's about 1" closed cell foam with a nylon spun carpeting on top of that. Add a good pad on top of it, and you have plenty of insulation on the bottom, which is where you lose most of your heat (as your sleeping bag is compressed under body).
  10. Sep 14, 2010 at 3:04 PM
    Maximus Gradient
    Maximus Gradient Well-Known Member
    Sean
    East Bay
    Red Taco, OR
    Blacked out chrome, TRD exhaust, rear diff. breather, hood/engine bay LED light strip, 235/85R16 DuraTracs
  11. Oct 19, 2010 at 6:42 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    +1 on a rechargable seperate battery pack. I have a Motomaster Eliminator. Can be used to jump up to a V6 (V8 models available) engine, and run either generic AC or DC appliances. Charges via AC or DC connecter.
    Have a look, there are many brands available. Just check to see what it is you want to run, and for how long, they come in a variety of sizes.
  12. Oct 19, 2010 at 7:27 PM
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    I have used a Mr. Heater Buddy heater and it works pretty well. Doesn't put of any fumes, and has an auto shutoff in case the unit tips over.
  13. Aug 8, 2011 at 6:58 PM
    rancher 420
    rancher 420 Well-Known Member
    Adam
    north east ohio
    2011 plain jane 4x4
    aftermarket fogs with HID LEER 100R cap pioneer head unit tinted windows silverstar reverse lights tow hitch cobra 75 c.b. vent visors new recovery hook in the front camping set up in the back ( rug, air mattress, fan, and heat)
    i ahve used the small catalitic heaters in my s-10 that i had halloween. frost on the ground. i had both side windows about half open for fresh air, and my thermometer i had in there said 78. i was sleeping well.
  14. Aug 8, 2011 at 7:15 PM
    1x1
    1x1 Well-Known Member
    NW Wisconsin
    '21 DCSB TRD OR
    RIP- ‘99 AC TRD, ‘12 DCLB TRD Sport
    I have used a mr heater big buddy. Let it warm the bed up before I hit the sack and turn it it off when I sleep. Turn it back on when I wake up. Propane gives off water vapor on combustion so there is an extra amount of condensation in the cap. I usual don't bring it with since I have a 3" matress I got from Cabelas.
