Heavier oils?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dtodd87, Feb 6, 2019.
  1. Feb 6, 2019 at 8:35 AM
    Dtodd87
    Dtodd87 [OP] Well-Known Member
    Dylan
    06 4.0L TRD OR
    Engine: 1GR-FE stock ARB Safari intake CSF Performace radiator Front Suspension: B8 6112 shocks B8 upper control arms Rear Suspension: B8 5160 shocks Deaver Expedition series 2 Leaf springs (stage 2)
    hello,
    I have a 2nd gen 06 Tacoma off-road and was wondering if people still use a heavier oil for older vehicles
    And if so my truck has about 195k, I’ve been using 5w-30 like most people, but lately have been noticing some low viscosity issues on my dip stick (barley sticking to dip stick) any advice would be great!
  2. Feb 6, 2019 at 8:39 AM
    Tacomax4
    Tacomax4 Well-Known Member
    2012 DCLB TRD Sport 4x4
    The dip sticks on our trucks are borderline impossible to read anyways. Stick with 5w-30 and preferably a full synthetic like Mobil 1 or Quaker State Ultimate Durability.
  3. Feb 6, 2019 at 8:44 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    maybe the dipstick isn't reaching the oil lol? I have no issues reading my stick been running Pennzoil 5w30 since I've owned the truck
    b_r_o and Dtodd87[OP] like this.
  4. Feb 6, 2019 at 8:51 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    i got 186k on my taco. ive been adding lucas oil heavy duty oil stabilizer seems to work.
    sparkystaco and Dtodd87[OP] like this.
  5. Feb 6, 2019 at 9:36 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Ive heard you can take a piece of steel wool or scotch bright to the bottom area of the dipstick and that will make reading it easier (the oil will stick better)
    inwood customs likes this.
  6. Feb 6, 2019 at 9:38 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    you can just get the High Mileage version of the oil, in the preferred weight
    BassAckwards likes this.
  7. Feb 6, 2019 at 9:39 AM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    What makes you think it works?
    soggyBottom and BillsSR5 like this.
  8. Feb 6, 2019 at 9:41 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    He gets better Mpg as his wallet is lighter.
  9. Feb 6, 2019 at 9:57 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    By "barely sticking", I presume you mean the oil barely shows at the tip of the dip stick? Or, is the oil sliding right off when you check it?
    In high mileage cars, the oil is likely entering the cylinder(s) past worn rings. Could also be worn valve stem guides; the car will usually smoke a bit at start up, especially when starting the engine after sitting a couple of days. A compression check can identify worn rings. Go to a 10/30 high mileage oil to see how much that helps. It helped our 07 ES350 with 220K+. There are additives that treat hardened valve stem guides you can look into if that is the issue. Are you doing 5K or 10K oil changes, or in between?
    If you mean that the oil really is sliding off the dip stick, then that's more a quality or condition of the oil. You may have coolant or ATF mixed in it. check your coolant and ATF levels to see if you are low. Coolant would give the oil a milky color, if you have enough of it.
    Dtodd87[OP] likes this.
  10. Feb 6, 2019 at 9:58 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    In the winter stick with 5-30. If you live in a very hot environment, maybe consider a heavier oil in the summer.
  11. Feb 6, 2019 at 10:02 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    What are low viscosity issues?
    There is no logical reason to get a heavier weight oil. It means it will not coat the engine as well.
    Less viscous oils coat colder engines better.
  12. Feb 6, 2019 at 10:06 AM
    coopcooper
    alberta canada
    aw man don't do him like that, plus its just 05s that get the ol razzle dazzle coolant in the oil isn't it
  13. Feb 6, 2019 at 10:27 AM
    Chuy
    Lakeside, CA
    Silver Taco
    Don't mean to scare him; just trying to cover multi bases. Yes, 05-06 models have a propensity for head gaskets to malfunction prematurely. However, if you neglect maintenance or drive in the red-line, any head gasket is likely to go kaput sooner than later.
  14. Feb 6, 2019 at 11:18 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I don't think you should change oil grades. The problem is that oil gets stuck inside the dipstick tube and you can't get a good reading until the oil drains down, which takes longer when the stick is in the tube. Wait at least 30 minutes after running the engine before pulling the dipstick. Sometimes I pull the stick when it's hot and leave it out, then wait 10 minutes because it the tube drains better when the stick is out... then do a quick in/out with the stick for a good reading. I used sandpaper to put some hash marks on my dipstick, makes it easier to read and the oil sticks better too.
  15. Feb 6, 2019 at 6:58 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Get you some of those safety glasses with the bi-focal reading lenses in them. You can see the oil better. It works for me.
  16. Feb 6, 2019 at 7:18 PM
    Dtodd87
    Dylan
    06 4.0L TRD OR
    Seems to not stay on the stick, not a complete run off but different than normal
    levels are good ATF and coolant, I live in a very hot climate in the summers (Louisiana)
    I do 3-5k changes, 5k if I’m pushing it, no smoke on start or noises
    Main part of the post was to see if a heavier oil would fix
  17. Feb 6, 2019 at 7:40 PM
    Chuy
    Lakeside, CA
    Silver Taco
    @Dtodd87
    That's generally not a reason to change oil viscosity. I will admit it's a bit odd - did you change oil brands or add an oil treatment? One would only change viscosity if your engine is burning oil or your gaskets have hardened and oil is seeping through. If you go thicker, you will get worse mpg and the oil pump will strain a little more; both of these are worth the trade off to lessen oil burning/loss but not otherwise, imo. You should consider submitting an oil sample for analysis to Blackstone or ALS Tribilogy (Wix brand). This will reveal abnormal levels of contaminants and if you op for the TBN value (standard with Wix package), you will find out how much oil life, if any, is left in your oil from when you took the sample.
  18. Feb 6, 2019 at 8:12 PM
    topoutman
    topoutman Well-Known Member
    Ellensburg, WA
    2013 DCLB 4X4 TRD SPORT
    Like already stated, our dip stick is shit. When you hear hooves hit the ground, think horses not zebras. :rimshot:
  19. Feb 6, 2019 at 9:04 PM
    Markcal
    Markcal Well-Known Member
    What I did like others here have mentioned was to take a sharp metal scribe and make a cross-hatch on the end of the dipstick, as you see on metal files, which really hold the oil well. My last truck was a Nissan and it's a night and day difference between the 2 dipsticks, my old Nissan had a dipstick with a cross-hatch design, making the oil really cling which made reading it very accurate.
    I would just scribe the end of your DS like this: ch.jpg
  20. Feb 6, 2019 at 9:31 PM
    Dtodd87
    Dylan
    06 4.0L TRD OR
    I’ll give it a try man, thank you for the advice
    Markcal[QUOTED] likes this.
