heavier or taller tires
Discussion in 'Wheels & Tires' started by stonedtaco08, Apr 17, 2016.
  1. Apr 17, 2016 at 7:10 PM
    stonedtaco08
    stonedtaco08 [OP] Member
    Marcus
    Prerunner
    is a taller tire worse on your mpg or a heavier tire? is diameter a bigger issue than weight is to try and keep mpg closer to stock? any input i know a heavier tire will lower mpg but is it more than the diameter alone or equal? ive seen some 265 70 17s that weigh the same as my 285/70/17... so i guess im asking is weight more of an issue or the diameter for mpg / performance. any input greatly appreciated.
  2. Apr 19, 2016 at 1:33 PM
    GeoBruin
    GeoBruin Well-Known Member
    BJ
    Los Angeles
    White 2014 Double Cab TRD Off Road
    DustStorm4x4 and greeneggsnspam like this.
  3. Apr 28, 2016 at 3:34 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Generally speaking, weight would be more of an issue.
    GeoBruin likes this.
  4. Apr 28, 2016 at 3:36 PM
    GeoBruin
    BJ
    Los Angeles
    That was the conclusion I came to in my calculations.
