Heaviest towable travel trailer for a 3rd gen OR??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mortavius141, Feb 15, 2021.
  1. Jun 22, 2021 at 11:55 AM
    #61
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Tundra’s aren’t running 300+ degrees. Not even dedicated race stuff will put up with that in higher pressurized cooling systems.
    The 5.7/6 speed super robust and I’ve seen plenty of them pull just fine through the mountains loaded heavy and not get hot. I’ve personally pulled plenty with one hooked to a race trailer with zero overheat problems. It will be remembered (if it isn’t already considered) to be one of the most durable powertrains ever put in a vehicle.
    The Tundra is hands down a much better tow vehicle than a Tacoma….
  2. Jun 22, 2021 at 1:14 PM
    #62
    Taco230032
    Taco230032 Member
    2016 TRD “bro” 4x4 (no longer a sport)
    Body armor 4x4 semi hidden winch bumper. Hooke road roof rack. Hooke road high height bed rack. Tyger nerf bars. MBRP front skid plate. TRD OR transmission skid plate stock added. TORQUE air bag suspension rear. 4:88 nitro gears. ARB rear lockers with onboard air compressor. KSP 2-4" UCA. Front Fox 2.5 with res with 3" lift. Fox 2.0 with LS adjustors. 2" AAL rear. Open country toyo 255/80/17 33” tires. Stock sport rims. Plastidipped everywhere!
    Oh I believe it that they are a better tow vehicle. Thats why I want one too...So i guess the temps Im reading off the tundra forum are lemons? Its like my taco under stress is considered baseline for the tundra. So I guess my temps are not bad at all. Have you gauged your temps? And do we need to modify it? Becuase these current gens have no trans cooler stock. Just off the tundra forums.
    Toyko Joe likes this.
  3. Jun 22, 2021 at 5:07 PM
    #63
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    I'll trust the engineers that build, design, and set industry standards.
    I think everyone knows a 6k load is a 6k load, including the dog, ice chest, etc.
    Little tractor trailer cabs that pull 80K must be nervous as heck.
  4. Jun 22, 2021 at 5:14 PM
    #64
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    I’d be looking at a 20’ 3500# trailer personally. By the time you load up the trailer and the truck to the gills it’ll be no fun to full time drive, let alone the single digit mpg, ha.
  5. Jun 22, 2021 at 5:32 PM
    #65
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    5400 loaded or unloaded? Unloaded it's way too heavy. Loaded it will do it but it's pretty miserable doing it. Your problem is you'll be over payload too easily. Should really go half ton truck for that weight. Personally from experience towing a 5500 pound loaded trailer with a Tacoma I wouldn't tow anything heavier then maybe 3500 pounds loaded with one. My Tacoma towing that 5500 point trailer never felt unsafe but wore you the hell out on long trips. Freaking no power, takes way too long to get to speed, damn thing is at 4000 rpm way too much and you better get a running start at any hills. You'll be looking at 9-11 mpg so with that little fuel tank you'll make frequent gas stops. A full size truck with a tow package will make the trip much more enjoyable in my opinion.
  6. Oct 10, 2021 at 8:35 AM
    #66
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    So I finally weighed my weight distribution setup. 2018 4WD SR5 dcsb towing loaded Winnebago micro Minnie 2108. Front axle 2680, rear axle 2700, trailer 4180. I did have my small generator in the bed as well. This seems ok to me. Anyone with more experience have any comments? Pretty close to payload max.
