Heavy Duty Bed Crossbars - Ready to Ship
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by KB Voodoo, Jan 4, 2015.
  1. Jan 16, 2015 at 10:08 AM
    cyakker
    cyakker Well-Known Member
    SD (at least we're not Mars)
    2015 AC, TRD-OR, V6
    Thanks Chad, glad you approve. :D
    I'd suspect that with the HD brackets there'd need to be some tweaking. Don't know if all Yak boxes have had similar mounts, with mine on HD I'd either need longer bolts w/ the stock mounts or start from scratch w/ new bolts & some washers to mount thru the slots.
    Where there's a will there's a way.
  2. Jan 28, 2015 at 10:24 PM
    G34
    G34 New Member
    Huntsville, AL
    14 X-SPX 4X4
    Can you work with/call RockyMounts to see if their BrassNuckles bike rack will fit on your bar? If so I would certainly by them. In addition, would your bars support 4 bikes about 85 lbs (21 lbs each)?
    I want to use my bed for gear and put bikes over the top of that.
  3. Jan 29, 2015 at 4:38 AM
    KB Voodoo
    KB Voodoo [OP] Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    There's always a way to get this stuff to mount.
    The bar can support a load of 400 lbs, so what you're looking to carry won't be a problem.
  4. Mar 23, 2015 at 10:25 AM
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    So i'm looking at this for a couple kayaks (with a hitch-extender for the rear rail). How much weight do the standard ones support? The kayaks are only about 50 pounds each and I'm only planning on carrying to anyway.
  5. Mar 23, 2015 at 10:45 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    You should be able to carry two kayaks on the standard ones, but to be safe, I would recommend the XRXS version.
    http://www.tacomaworld.com/forum/2n...ce/364558-xrxs-bed-cross-bars-ready-ship.html
  6. Mar 23, 2015 at 12:15 PM
    snowmanwithahat
    Thanks, I saw those, but quite frankly I like the standard or the HD ones better. Is there a significant difference between the HD ones and the XRXS version? If anything I think the raised height off the bed sides would be good for a kayak.
    All the products look great, I'm starting to save for a bed-overhaul (side rails, tailgate reinforcement) and some crossbars
  7. Mar 23, 2015 at 12:25 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Strength wise, yes. The HD bars are ridiculously strong, probably overkill for kayaks. I designed them with RTT's in mind.
  8. Apr 4, 2015 at 11:55 AM
    dust999
    dust999 Active Member
    MA
    09 tacoma
    Do these come with the cleats?
  9. Apr 4, 2015 at 6:09 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    They do not. Your truck should have four of them.
  10. Apr 7, 2015 at 4:23 AM
    mauigrown
    mauigrown Well-Known Member
    2011 4x4 DCSB TRD sport
  11. Apr 7, 2015 at 4:34 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  12. Apr 8, 2015 at 4:29 AM
    dust999
    MA
    09 tacoma
    Liked these bars for my new RTT so I pulled the trigger and bought a set. Shipped and packaged well, no scratches, nice set of bars. Unfortunately my tacoma cleats do not clamp tight enough to keep the bars from moving up and down when installed. Not good with a heavy RTT wanting to bounce around on a rough road. Cable ties was the suggested solution by the vendor, not sure if this is a good long term route. Another discussion lead to some drilling of holes to fasten the bar directly to the outside edges of the cleat.....I will be testing them later in the week to see how they hold up.
  13. Apr 8, 2015 at 4:48 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    How is that possible? I have the standard bars with the cargo basket and they've never moved. I have to make sure the knobs are fully depressed on each one to get the bar to move at all.
  14. Apr 8, 2015 at 4:15 PM
    dust999
    MA
    09 tacoma
    Take a look at the pictures of mounting them at the beginning of this thread. If the cleat does not provide enough force to really tighten up, the bar moves around and up and down because of the large hole for the cleats bolt to go through. I think the normal bar attaches directly to the cleat with bolts, hence no movement.
  15. Apr 12, 2015 at 5:20 AM
    #35
    dust999
    MA
    09 tacoma
    Simple fix to tighten the bars down.
    Fastbilly5 likes this.
  16. Jun 14, 2015 at 7:26 PM
    #36
    OneFastGeek
    OneFastGeek Grand Master Fu
    Treasure Valley, Idaho
    2010 TRD Sport 4x4
    So I'm looking to put together a roof basket storage solution similar to this...
    I'd like to go with HD cross bars instead. However, I've got an All Pro Offroad bed rack that covers the entire length of the factory cleat rails.
    [​IMG] [​IMG]
    To mount the cross bar in lieu of the bed rack, I'd drill out the flat side of the hole in the cleat and replace the T-bolt with a standard bolt. I figure I'd probably have to flatten the bottom on the cleat to make things line up as well. The other thing is I will have to find some type of large washer to cover the loop part of the cross bar.
    Do you think this setup will work?
    Sand Shark likes this.
  17. Jun 14, 2015 at 7:56 PM
    #37
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It should work. You'll want a fender washer.
  18. Jun 15, 2015 at 8:13 PM
    #38
    allpro
    allpro Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    Give us a call or email me, maybe we can help you so you have something that works well with your rack!
    Tracy
    tracy@allprooffroad.com
  19. Jun 23, 2015 at 7:47 AM
    #39
    snowmanwithahat
    Wanted to post some pictures of what I've done with these bars. Hopefully other users find this useful.
    I bought a pair of these bars to try and replicate what SCHMEGGA did with his build.
    https://www.tacomaworld.com/threads/schmeggas-08-black-silver-build.159898/page-2#post-3325687
    Well my kayaks ended up being a little bit longer (9.5 foot instead of 8.25). Between the extra length and the fact that REI didn't have any J-hooks available at their store when I picked up the kayaks (wtf?)
    So I ended up doing this janky in-the-bed strapped down setup. It worked to get them home, but it wasn't great. I am taking a trip at the end of June which involves a 4-hour drive into northern Michigan. I'm going to have 4 people in the cab, 4 people worth of luggage and food for 8 in a cooler (another group is meeting us up there). So having my bed accessible is an absolute must based on this trip.
    I ended up adjusting my initial plans (SCHMEGGA's design) and going with a hybrid approach with one bed crossbar and then another crossbar supported by the trailer hitch. This hitch crossbar was built out of aluminum scrap that we have and painted black to hide how old the metal was (old mangled remains of a boat-lift that got picked up and tossed during a storm).
    To be completely honest a couple kayaks is hardly stressing the capacity of KB Voodoo's bed crossbard or the aluminum hitch bar that I built. I planned on building these so they're both reusable for other types of material and in the future I'll probably get a chance to stress it out with some loads of 2x4 wood or 2x4 steel tube for at trailer I'm going to try and build.
    Ultimately I'll probably retire these crossbars from use for kayaks and move to a roof-rack (Probably Pr1nsu w/ J-hooks). I'll probably end up relegating these crossbars to use with a RTT in the bed or maybe a basket for carrying fragile gear and keeping it out of the lower section of the bed.
    Very solid crossbars, and a real clean design. I definitely would recommend this to anyone looking to pick up a crossbar.
    KB Voodoo[OP] likes this.
  20. Jul 6, 2015 at 9:20 PM
    #40
    snowmanwithahat
    Noticed an interesting thing on the way back down from my trip this week. The force from the straps that I ran at the front and rear of the kayaks was enough to start to cave in the plastic side-cap underneath the bedrail. Looks like a set of steel rail-caps are in order soon (of the KB Voodoo flavor of course)... I swear they got 90% of this truck right but really skimped on the pieces that really should have been built tough.
