heavy duty bumpers without beefing up suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tfeltz73, Aug 6, 2013.
  1. Aug 6, 2013 at 6:29 PM
    tfeltz73
    tfeltz73 [OP] That's greasy Ricky
    central Wisconsin
    2013 supercharged long travel thing
    Has anyone tried putting on a front and back heavy duty bumper without beefing up the suspension. I just ordered a front and back from all pro and I know I don't have to worry about the rear but just wanted to know if I can go without a heavier front suspension, thanks.
  2. Aug 6, 2013 at 6:51 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Stock springs/shocks on my front & the ARB dropped it a tad over .5"
  3. Aug 6, 2013 at 6:56 PM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    It's going to pull it down a bit but the biggest issue you will have is dampening. Slowing all that weight down takes heavier spring and appropriate shock valving. You will get more familiar with your bumpstops for sure. You can get away with it but best to match your suspension for the weight for both performance and safety.
  4. Aug 6, 2013 at 6:58 PM
    RyanK1
    RyanK1 Well-Known Member
    Penticton, British Columbia
    2006 Tacoma TRD Sport
    Bilstein 5100's @ 2.5, TSB rear with block spacer, Procomp ES9000's, CBI Moab 2.0 front bumper, swaybar removed, DIY HiLift mount, Rear diff breather mod, ABS Kill Switch, Flowmaster 40 series muffler, Superwinch 8500
    CBI Moab with Superwinch 8500 on stock coils and 5100's, noticed a negligible amount of drop.
  5. Aug 7, 2013 at 5:45 AM
    tfeltz73
    central Wisconsin
    What spring and shock should I buy
  6. Aug 7, 2013 at 6:39 AM
    The109
    The109 Well-Known Member
    Fort Collins
    2013 TRD OR Access Cab
    Subbed for info.
  7. Aug 7, 2013 at 6:41 AM
    Large
    Large Red
    Depends on the weight of the bumper and if you are going to add a winch, also your preferences on ride quality and your budget.
  8. Aug 7, 2013 at 6:49 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I rode with my ARB on stock suspension for a while. I hated it. I lived in the mountains and it was not pleasant driving on curvy and steep grades. I chose to put on OME 886 and matching Nitrocharger shocks.
  9. Aug 7, 2013 at 8:05 AM
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    What kind of driving/off-roading do you do? What kind of budget will you be working with when you do your suspension?
  10. Aug 7, 2013 at 9:55 AM
    Baoser
    Baoser Well-Known Member
    George
    Pittsburg, CA
    2012 DCSB Offroad
    BruteForceFab front and rear bumpers on Stock OR suspension for a couple of months along with different wheels and stock tires. Drive normally and you'll be fine.
  11. Aug 7, 2013 at 9:58 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Drive normal varies for everyone. Normal for my terrain was horrible with the ARB on stock.
  12. Aug 7, 2013 at 10:05 AM
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    How much lift did you get? Ride quality? Did you do UCAs? I just got my Elite front bumper, looking to put a warm M8000 in there, I have LR UCAs to put on, just gotta pull the trigger on suspension, thinking of going with the 886 and Nitrochargers. Stupid money pit.:rolleyes:
  13. Aug 7, 2013 at 10:08 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    about 3", I was excited and forgot to measure. The bumper was on the stock suspension so measurements wouldn't have been accurate. I have LR UCAs, I like the ride, some say it's too stiff but it's not there truck. More weight would make it softer.
  14. Aug 7, 2013 at 10:45 AM
    tfeltz73
    central Wisconsin
    I do a lot of city driving and only do a little off roading. I don't have that big if budget because of spending $2,000 on the front and rear bumper but I could probably manage around $500 for some better suspension.
  15. Aug 7, 2013 at 1:39 PM
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Good all around multi-purpose set up would be old man emu. Won't break the bank, performs well for about anything.
  16. Aug 7, 2013 at 3:24 PM
    tfeltz73
    central Wisconsin
    Thanks and where can you buy them from and is that all its called is ome?
  17. Aug 7, 2013 at 3:59 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Many of the vendors on this forum sell the OME kit. For front suspension, it would include a pair of front shocks, pair of front springs. A trim packer, heavier duty front springs and carrier bearing drop are some optional items.
    But... that will still lift you >2.5" over a stock suspension in the front. You indicated in the initial post that you don't want to mess with the rear suspension.
  18. Aug 8, 2013 at 11:14 PM
    jameskhana
    jameskhana Maibatsu Monstrosity
    James
    Dallas, TX
    2007 DCSB Base 4x4 6spd
  19. Aug 9, 2013 at 12:08 AM
    penguins_cc
    Will
    Bellevue, WA
    ^^^ Fantastic point :p
