Heavy duty steering rack
Discussion in 'Technical Chat' started by 1stgen, May 3, 2016.
  1. May 3, 2016 at 10:06 AM
    1stgen
    1stgen [OP] Well-Known Member
    Dade City/ Ft. Myers, FL
    18 SR5
  2. May 3, 2016 at 10:15 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    I doubt it. Says it just a remand unit. For another $75 bucks you could get a brand new oem unit. Which is what I have found to be the best replacement. You could also check out cvj for oem remand units. They run for less than the trailgear units. There is also rack doctor that a lot of guys have had good results with. I am curious though I have not heard or read anybody using these traikgear units...but have heard that the brand trailgear over all is not the best quality parts. Good luck in your search:thumbsup:
  3. May 3, 2016 at 10:59 AM
    1stgen
    18 SR5
    Just don't want to keep replacing them. I couldn't find the cvj or the safari ltd to buy.
  4. May 3, 2016 at 11:02 AM
    FirstGen Jer
    Jeromey
    The cvj is on there site. Note sure about safari? Rack doctor is a good one though.
  5. May 3, 2016 at 11:08 AM
    1stgen
    18 SR5
    Found the rack doctor one. Probably going to do that one.
  6. May 3, 2016 at 12:43 PM
    onedivinetaco
    onedivinetaco Well-Known Member
    botolphston
    '05 dcsb 4x4
  7. May 3, 2016 at 12:53 PM
    FirstGen Jer
    Jeromey
  8. May 3, 2016 at 1:41 PM
    1stgen
    18 SR5
    Probably like a cover for the outer tie rod.
  9. Sep 23, 2016 at 9:39 PM
    FirstGen Jer
    Jeromey
    @1stgen what rack did you end up with?
  10. Sep 25, 2016 at 11:43 AM
    1stgen
    18 SR5
    Ended up just replacing the outer and inner tie rods with moog and 555 Japan.
    FirstGen Jer likes this.
  11. Nov 14, 2018 at 6:13 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Stumbled upon this thread while trying to find a HD rack. Careful if buying from cvj. They have three options and you're going to want the most expensive one and I think at that point it's more than oem. The lowest priced one uses the the roller guide, the step up uses the bushings but there inner tie rod limits your down travel thus destroying them (this is the one I purchased), I'd assume the top dollar one has good tie rods.
    So a year and a half of use and the octonut on the control valve completely backed out and left me filling my boots with atf. This nut should have been peened to prevent this and there was no sign of it. Since I had the rack apart I thought I might as well replace all the seals and ended up scoring the inside of the cylinder leaving it fubar. Before disassembly I tried getting it covered under warranty but I didn't think to find my receipt when i took it to there shop before I tore it apart. I guess they don't keep records of credit card purchases. Anyway my fault there for not thinking of that before hand.
