Heavy Duty Suspension for Stock Ride height
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SoonToBeOn39s, Mar 20, 2022.
  1. Mar 20, 2022 at 8:15 AM
    SoonToBeOn39s
    SoonToBeOn39s [OP] Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    Does anyone know of a brand that sells heavy duty rear leaf springs and heavy duty front coil springs that does NOT require a lift for a 3rd gen? All I'm finding are heavy duty leaf springs and coils for a 2 - 3 inch lift.
    Thanks!
    tinker_troy likes this.
  2. Mar 20, 2022 at 1:38 PM
    TacoVErmont30
    TacoVErmont30 Well-Known Member
    2021 DCLB OR
    I’ve been looks for the same to no avail
  3. Mar 20, 2022 at 1:44 PM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    Deaver can do any specification you want in your rear leafs. As far as the front goes you might ask Deaver about that they would know.
    SoonToBeOn39s[OP] and eurowner like this.
  4. Mar 20, 2022 at 1:52 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    What are your goals? The stock coil springs are the highest spring rate springs for the taco that I know of. Leaf spring manufactures don’t publish much of any specs, but you can assume that adding more leafs will increase the spring rate. But you have to realize that increasing the spring rate without changing anything else is going to increase your ride height.
  5. Mar 20, 2022 at 2:03 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    not true with leafs, depends on the engagement of of the springs. You can start out at stock ride height and have heavy spring(s) engage quickly. The ride would suck but it’s possible
  6. Mar 20, 2022 at 2:11 PM
    gudujarlson
    Minnesota
    I don’t disagree. I was thinking of adding more leafs to the pack.
  7. Mar 20, 2022 at 2:46 PM
    SoonToBeOn39s
    I was going to add a Truckboss midsize sled deck to my 2020 Tacoma. I have found an alternative. I think I'm going to use an ironman 4x4 add a leaf kit along with Firestone air bags.
