heavy duty suspension
Discussion in '1st Gen. Tacomas (1995-2004)' started by green machine, Sep 28, 2011.
  1. Sep 28, 2011 at 6:59 AM
    green machine
    green machine [OP] Member
    Frank
    Washington, PA
    03 Tacoma
    Any suggestions on beefing up the rear suspension for heavy hauling on on first gen? I haul a lot of wood through out the year for my wood burner. I probably haul too much weight but the old girl just keeps trucking. If, and when, my stock back shocks go i would like to make some up grades.
    thoughts?
  2. Sep 28, 2011 at 7:17 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Allpro expedition leafs. They take 400lbs before they sag. However they do give like 4'' of lift..
    So with those you'd need a longer brake cable for the rear. Might as well lift the front too with billy 5100s and Eibach coils. You'll need extended travel rear shocks as well.
    Then you'll realize your tires are too small and want to upgrade those but you dont NEED to.
    All in all, new leafs is the best you can do. Expo leafs are the most heavy duty ones you can buy right now.
  3. Sep 28, 2011 at 8:29 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    If you're hauling a lot of weight frequently, then I'd look at some custom leaves like Alcan or Deavers.
    Some seem happy with the AllPro Expo leaves.
    I've been happy with my OME Dakars, but ONLY with the D6XL extra leaf added. the Dakars won't handle your weight with the AAL.
  4. Sep 28, 2011 at 11:54 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If you don't really want lift, but do haul a lot weight from time to time, I would suggest a set of TIMBRENS and a new set of Shocks to help dampen the load.
  5. Sep 28, 2011 at 2:20 PM
    Talbotman
    Talbotman Well-Known Member
    Joel
    Ripon, California
    2002 "Toy Taco"
    3" custom lift kit, 285/75/r16 toyo open country AT's, Billy 5100's in front and 5150's in back, Weld 16x10 rims, Flowmaster 2 chamber, 6000k bi-xenon hid kit, grey wire mod, and smoked tail lights
    i would suggest getting some load leveling air bags. i got a set of air bags and fabbed up some mounts and just ran some air lines, the longest part was fabbing up the mounts but they helped me pull 5,000 lbs of olives with a 16 foot trailer and my truck didnt squat at all:D:D:D
  6. Sep 28, 2011 at 3:39 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    That's a lot of olives :eek:
  7. Sep 28, 2011 at 9:28 PM
    Talbotman
    Joel
    Ripon, California
    2002 "Toy Taco"
    yeah they make extra virgin olive oil lol
  8. Sep 29, 2011 at 6:09 AM
    richsteele
    richsteele Member
    99 Reg cab 2.7L 4x4
    Dash & heater panel LEDs, stereo & speaker upgrades, 2004 side mirrors, Safe-T-Cap mid-frame section repair kits.
    Another suggestion - Northwest Off-Road makes heavy duty replacement rear springs. They claim 700 lbs. additional load capacity with only 3/4" lift over stock springs. I haven't found very much on the forum about them but maybe if someone has them they'll post a review.
    northwestoffroad.com/parts/2stage.php
  9. Sep 29, 2011 at 2:09 PM
    Cjd
    Cjd Member
    East Tx
    2011 4.0 TRD OR 4x4
    Stock except for some small stuff: Diff breather mod, fog lights anytime, interior LED's, hose clamp mod, ultraguage, locking console, stealth mode mod, disable seat belt beep, Hellwig 550 helpers
    For shocks check into Monomax I have them and they are STOUT they about beat me to death though on rough roads if I aint hauling anything
