Heavy Duty Suspension?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SerialKiller, Jan 10, 2021.
  1. Jan 10, 2021 at 8:31 PM
    SerialKiller
    SerialKiller [OP] Well-Known Member
    2019 Cement Tacoma OR
    I was wondering does anyone makes a heavy duty suspension that doesn’t add lift? I’m happy with the stock height and not looking to lift I just want to be able to haul a little bit more.
  2. Jan 10, 2021 at 8:37 PM
    FloTaco
    FloTaco Well-Known Member
    Bay Area, CA
    2021 SR DC 4X4
    You’ll want airbags rather than different springs.
  3. Jan 11, 2021 at 5:31 AM
    N5J_Taco
    N5J_Taco Well-Known Member
    2.5 shocks (Heavy Duty) from ADS, FOX, Kings, OME, and Bilstein are offered from 0-3 inch. They are adjustable so if you get sag you can raise as needed. As for the rear suspension you can add 1 leaf (that will raise the rear about 1") Sumo spring (Block of rubber to prevent rear sag when loaded) or as mentioned air bags.
  4. Jan 11, 2021 at 6:48 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    The shocks are kind of moot since they provide dampening. He would just need heavier coils but unlikely he needs it for the front.
    Deaver can build a pack for you if you decide to swap springs to meet your needs but expect to pay around $1k. Air bags may be your best option.
    hiPSI and whatstcp like this.
  5. Jan 11, 2021 at 6:51 AM
    FloTaco
    Bay Area, CA
    2021 SR DC 4X4
    He’s looking for a solution that adds zero lift. There are currently only 3 options for his problem:
    1. Have Deaver build a custom zero lift heavy duty leaf pack.
    2. Remove the stock overload leaf and replace with a custom overload of a higher spring rate but NOT with more arch.
    3. Air bags.
    Option 2 is easy and cheap but will affect your right quality. Option 3 will not affect your ride quality and can be inflated only when towing.
    MannyS likes this.
  6. Jan 11, 2021 at 6:52 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Ummmm...... could you make a weight estimate on "....to haul a little bit more."
    How much is a "..little bit.."?
    As is, the truck will carry about 1000 lbs of cargo, people and add-ons.
    Chew likes this.
  7. Jan 12, 2021 at 9:40 AM
    SerialKiller
    From time to time I’ll go to a landscape supply and pickup a load of dirt, rock or sometimes pressure treated lumber. It’s a few times a year I have a lot of weight in the back and it looks ridiculous but I’m probably hurting the truck. I live in PA and the potholes are bad. I’m not to keen on airbags I would prefer a beefier leaf pack. In the future I would like to add some sliders and armor. Also is there options for the front because I would like to add a steel bumper? My truck spends most of the time on the road with light wheeling and I don’t need a lift because most of the trails I go on my stock Tacoma is more than capable.
  8. Jan 12, 2021 at 9:49 AM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Sumo springs or timbrens if you wanna go that way. No upkeep. Brother installed them on his and he’s happier than a pig in shit.... this after I did airbags on mine and fill em up, let air out and so on.... I don’t mind it.
  9. Jan 15, 2021 at 8:31 AM
    SerialKiller
    I know AAL will lift the rear but what would give it more load capacity a single leaf or one that replaced the overload spring like the Icon?
  10. Jan 15, 2021 at 10:44 AM
    FloTaco
    Bay Area, CA
    2021 SR DC 4X4
    I believe an overload replacement will resist sagging without lifting. Add a leafs usually increase arch and spring rate, where a heavier overload resists deformity.
  11. Jan 15, 2021 at 10:49 AM
    eurowner
    eurowner Duke Sky
    Scoty
  12. Jan 15, 2021 at 10:52 AM
    FloTaco
    Bay Area, CA
    2021 SR DC 4X4
    The Sumo bump might actually work as they come in various rates.
    T-yoda likes this.
  13. Jan 15, 2021 at 11:06 AM
    SerialKiller
    Thank you everyone for your input. Does anyone have any complaints about Icon AAL? How much lift does it give you and what are good shocks to pair up with them without breaking the bank?
  14. Jan 16, 2021 at 2:28 AM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    FYI. Altering the suspension may impact your ride comfort. Not a big deal for some owners while others may appreciate the firmer ride characteristics of a modified suspension.
    whatstcp likes this.
  15. Jan 19, 2021 at 9:54 PM
    rebma63
    rebma63 Member
    Don
    Sparks, NV
    2017 Tacoma SR5 AC Super White
    Leer 180 Cap, RCI front skid plate, DSM dash top mount, dog platform, in bed bike rack
    I just installed the Sumo black 1000# version. I’ll be towing a 4000 lb-ish (loaded) travel trailer. Have not towed with them yet but notice little change in the unloaded ride. So far extremely happy with them.
  16. Jun 21, 2021 at 2:04 PM
    Oerski
    Oerski Well-Known Member
    Nick
    San Antonio
    2015 Tacoma PreRunner
    How did they end up working out for you loaded?
  17. Jun 21, 2021 at 2:15 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    I did Sumo Springs, cheap easy fix for me. Something to consider.
  18. Jun 21, 2021 at 3:01 PM
    Oerski
    Nick
    San Antonio
    And they will work with MD Dakar’s I’d imagine
  19. Jun 21, 2021 at 3:08 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Air bags will be only way to not add lift and maintain current ride quality. Closest thing possible to having your cake and eating it, too.
    hiPSI likes this.
  20. Jun 21, 2021 at 6:11 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    OP if you re spring and don't haul except a few times a year... your ride is going to be shit the other 363 days. Air bag it and be done. Only pump them up when hauling. Takes two minutes... or squat like the rest.
