Heavy E-Load tires and stock suspension?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by REKER, Nov 22, 2021.
  1. Nov 22, 2021 at 11:32 AM
    REKER
    REKER [OP] Well-Known Member
    Virginia Beach
    2016 Magnetic Gray Tacoma TRD Sport 4X4 - DCSB
    I've about worn through my Falken Wildpeak SL-loads and the tires I want to upgrade to are an E-load. I dont do any offroad driving or towing, so the "need" for an E-load is non-existent. From the listed weights, there is a 9-10 lb difference. For those of you using a heavier/larger tire size with stock front suspension, have you had any issues with premature front end wear over the long term, since the larger mass and wider footprint add greater rolling resistance and weight on the parts?
    I know the powertrain performance will decrease, but was there a drastic performance decrease for you on the butt-dyno?
  2. Nov 22, 2021 at 11:34 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    get C rated if you dont wheel or have a heavy rig. You can get just as "meaty" of a tire and your wallet and mpgs will thank you. Most popular tires (dependent on size) come in E and C rated (much lighter).
    The truck will def feel slower and butt dyno will be less as well.
    OmahTako, GillyLink and Ronbo5 like this.
  3. Nov 22, 2021 at 11:34 AM
    LiquidArrogance
    LiquidArrogance Well-Known Member
    Streets of Bakersfield
    2021 SSM Sport 4x4
  4. Nov 22, 2021 at 11:36 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I'm with @LiquidArrogance. Why would you want to run E if you didn't have to? What tire you looking at that doesn't come in a lower load rating?
  5. Nov 22, 2021 at 11:37 AM
    REKER
    Virginia Beach
    If you didnt cut my sentence up to be what YOU wanted to read, your "why?" would be answered......
  6. Nov 22, 2021 at 11:39 AM
    nudavinci64
    Robert
    Still didn’t answer why. If your looking for a bigger more offroad get a C rated version. How much higher if a tire? If it’s not much bigger it won’t be as dramatic. You could go 265/75/16 C rated and get the look you want assuming that’s why.
  7. Nov 22, 2021 at 11:43 AM
    REKER
    Virginia Beach
    If they came in a C load for the size I want, I would.
    Unfortunately they only come in E load. Theyre the MT Baja Boss in 265/70R17.
    I get it fellas, why why why. I fully well know it sounds dumb as hell.... but thats not my question.
  8. Nov 22, 2021 at 11:45 AM
    REKER
    Virginia Beach
    I dont WANT to upgrade to an E. The tires I want are only offered in an E. Make more sense? I have 3 more tire options, but the tires I really want just so happen to only come in an E-load.
    nudavinci64 likes this.
  9. Nov 22, 2021 at 11:45 AM
    nudavinci64
    Robert
    Got it. If you are stuck on that specific tire you will feel a difference in MPG and Butt Dyno. Maybe not as much as larger tires but it will be noticeable. Update to ONLY offered in an E-Rate and the tire would have prob reduced the comments 99%.
    I am considering looking at D-Rated to bridge the gap but similar to you the tires at the time I wanted were only E-Rated ( currently running KM3).
    gsubioguy and REKER[QUOTED][OP] like this.
  10. Nov 22, 2021 at 11:47 AM
    REKER
    Virginia Beach
    Thanks, yeah I figured. Mainly interested in if anyone has noticed/had any premature front end wear.
  11. Nov 22, 2021 at 11:47 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Your front end will be fine. Your over thinking it. Buy the tires.
  12. Nov 22, 2021 at 11:48 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    I would avoid E if you don't have to and look at other offerings. That being said its harder to find c-range tires in bigger than stock 17" wheels.
    Not because of suspension wear but because of the ride quality and power/mpg loss like others have said if the tire is heavier than its c/d range counterparts.
    MJTH and Junkhead like this.
  13. Nov 22, 2021 at 11:49 AM
    nudavinci64
    Robert
    yah in terms of wear they will likely be fine. A M/T tire is going to wear funky anyway if all you do it drive on the street. Also may not last as long
    Junkhead likes this.
  14. Nov 22, 2021 at 11:49 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You will be perfectly fine. I ran e loads on my stock suspension and had no issues at all. I noticed no power loss whatsoever. At the most you might get 1-1.5 mpg hit and the ride will be a bit harsher. If you don’t mind those things then go for it.
    FWIW I still got better or advertised MPGs with e load tires. Have c loads now and they are great, can still air down off-road and the ride is much nicer on the street.
    I would avoid heavy MT tires if you are street driving only. MTs are not great when raining and just in general street performance.
  15. Nov 22, 2021 at 11:51 AM
    REKER
    Virginia Beach
    Yeah, pretty much where im at..... but the MT Baja Boss AT's look great and have a 55K warranty. haha.
    Meh... you're probably right.... but...
  16. Nov 22, 2021 at 11:53 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    You sure those MT Baja Boss come in 265 ?
    Aqualoon and Junkhead like this.
  17. Nov 22, 2021 at 11:53 AM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    No buts about it. People run e loads on factory suspension all the time. The only tacoma owner that would obsess over such a topic is a tacoma owner thats a member here.
    Once again.
    Your suspension will be fine.
  18. Nov 22, 2021 at 11:53 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    X2
    REKER[OP] and jlemmond[QUOTED] like this.
  19. Nov 22, 2021 at 11:56 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I really wanted coopers STT pros, but they only come in E load, too bad because it’s an awesome tire.
    I would only run E load if all I did was rock crawl at 15 psi.
  20. Nov 22, 2021 at 11:56 AM
    REKER
    Virginia Beach
    Im talking front end suspension parts/ball joints/wheel bearings, etc....
    Thanks for the feedback! I'm not worried about a minor MPG loss (Thanks Bo Jiden), mainly just front end components wearing out prematurely over the long run.
