Heavy load baring rack attachment to front bumper – your opinions appreciated.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cadmus, Sep 25, 2016.
  1. Sep 26, 2016 at 11:59 AM
    Wulf
    rock raisin
    Cadmus[OP] likes this.
  2. Sep 26, 2016 at 12:02 PM
    Cadmus
    Cadmus [OP] Un-Known Member
    Fort Collins CO USA
    '04 4door 4x4 TDRoffroad
    Those have GREAT potential. If not for this project, surely for other projects.
    Square tube also available ($40-50 each)
    http://www.chassisunlimited.com/product/tube-clamps/square-interlocking-clamp.html
    ---------------EDIT---------------
    Unable to find specs on these, if anyone does please post um. But if made for roll cages, they are likely strong enough.
  3. Sep 26, 2016 at 12:36 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Something like this? [​IMG]
  4. Sep 26, 2016 at 12:37 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Mmmm, that helps give some ideas...
  5. Sep 26, 2016 at 12:39 PM
    cruiserguy
    Elijah
    SEKS
    Along with those cool interlocking tube deals.... Has potential, OP?
  6. Sep 26, 2016 at 12:52 PM
    Cadmus
    Fort Collins CO USA
    The rack you show is what most hang glider pilots build. I have owned/built them. But i have a 1' diameter PVC tube permanently mounted far to one side. When I did this with a rack mounted as in that photo it caused too much wobble and too much wear and tear on the dacron. So i need to locate supports to the outside (i used the medical analogy "lateral not medial") of the body, just behind the lights and in front of the wheel. This has many advantages. 2 front receiver hitches just medial to the lights (as in the photo @ClevSix posted) is most common for that type of rack. It is my fall back design and can be mounted to the bottom of the winch plate of the bumper i linked to. But i plan to own this truck for several decades so I want to do it right .
    If those black tubes are the sleeves for that rack it IS sturdy. It is easier to make such a rack if you do not need an off-road approach angle. Which i am trying to maximize.
    So many things to balance...
    I can not get deflection or strength ratings for different forces on those interlocking cage joints. but they are cool. Not as quick as a pin but way sleeker.
    Thanks for the help everyone... this is getting good
    -----EDIT----
    Changed "people" to 'hang glider pilots'.
    added "When i did this with a rak mounted as in that photo it cause too much wobble and too much wear and tear on the dacron" "and can be mounted to the bottom of the winch plate of the bumper i linked to" "as in the photo @ClevSix posted"
