Heavy load till Friday.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Viking88, Apr 5, 2010.
  1. Apr 5, 2010 at 8:14 AM
    Viking88
    Viking88 [OP] Devil's Advocate
    Budd Lake NJ
    2009 TRD Sport DC 4X4
    I did a bathroom re-model over the weekend, and all the debris is sitting in the back of my Sport double cab. I wont have time till Friday to bring it to the transfer station and dump it, so the truck is stitting in my garage. By how low the back end look I can tell its pretty heavy.
    It wont hurt anything having the springs / shocks compressed sitting there for a week will it? Its not like I'm driving it around.
  2. Apr 5, 2010 at 8:19 AM
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    if your worried about it just lift it up with a jack and put some jack stands under the frame to keep the weight off the suspension. my guess is you would be ok leaving it that way though.
  3. Apr 5, 2010 at 10:30 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    If you haven't had the rear leaf TSB done, now's your chance.:D
  4. Apr 5, 2010 at 11:25 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    yup, go and see if you're close to hitting the bump stops. If you are, take it to the dealer and complain of a harsh ride while under load.
  5. Apr 5, 2010 at 12:43 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    You should be fine, but if it makes you feel better, you can support it like mtnbiker said.
  6. Apr 5, 2010 at 1:13 PM
    Viking88
    Budd Lake NJ
    But if I get the TSB done, then wont I have a harsh ride when NOT under load?
  7. Apr 6, 2010 at 4:33 AM
    nxtruck
    nxtruck Member
    I had the spring TSB done 2 or 3 weeks ago on my 2010 trd sport. I havent had a chance to load my quad in it yet, but I find the truck rides much better now unloaded than it did new. T
