Heavy shaking at low speeds
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trufflie, Feb 12, 2016.
  1. Feb 12, 2016 at 3:03 PM
    Trufflie
    Trufflie [OP] New Member
    2001 TRD tacoma
    Hello all!
    I have a 2001 Toyota Tacoma prerunner Trd
    Having an issue with the rear driver side wheel completely locking when braking or at low speeds (1-10 mph)
    The truck shakes extremely hard and sometimes causes the wheel to actually lock and skid.
    I recently replaced both front rotors and calipers, and the problem started around the same time.
    First mechanic I took it to said the entire rear end assembly was bad, and needed to be replaced, and another said it was an abs issue.
    Has anyone had this problem before or know of a fix?
    Keep in mind, t doesn't always do this, just sometimes, usually when I'm in parking lots, and drivethrus.
    Thanks for your time
  2. Feb 12, 2016 at 10:05 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I fought the same problem for about a year. Replaced pads, calipers, diff oil (I have an LSD), nothing worked.
    Replaced the rear shoes with OEM ones fixed it completely.
  3. Feb 12, 2016 at 11:23 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    A little bit of oil on your shoes will do this exact same thing. Caused by a slightly leaking axle tube seal or even being careless with greasy fingers/tools when the rear drums were off.
    Just a possibility...
  4. Feb 13, 2016 at 4:09 PM
    Trufflie
    2001 TRD tacoma
    Just had a brake inspection done and they found leaking seals and the shoes were soaked.
    However they told me that wouldn't cause this particular issue.
    It's only 375 to fix so I'll see if that's the issue
  5. Feb 13, 2016 at 8:50 PM
    bry838
    oregon
    Ahh, i really suspected that by your symptoms! I guarantee you with absolutely no doubt when you get new shoes and clean the piss outta your drums (cause they are now oil soaked) that problem will dissappear! Im sorry but those or that mechanic are dead wrong about that not being the problem.
    But really be sure the drums get cleaned well and of course the shoes need replaced, which im sure you knew, theres no salvaging them unfortunately.
  6. Feb 13, 2016 at 11:14 PM
    bry838
    oregon
    Tell us how it ends though, please?
  7. Feb 15, 2016 at 12:53 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    brake master cylinder will do this..check your brakes to see if they are hotter than normal after a 3-5 mile trip. it can mean your brakes are dragging.
