Heavy Shaking while off road
Discussion in '1st Gen. Tacomas (1995-2004)' started by 530to707, Dec 16, 2013.
  1. Dec 16, 2013 at 8:58 PM
    530to707
    530to707 [OP] Well-Known Member
    NorCal
    2015 trd sport 4x4 doublecab
    Hey dudes,
    So i took my rig off road to work today for the first time. I drive to timber sites deep in the woods on roads that usually very bumpy. My old tuck was an automatic 2002 ranger, and i dont recall it seeming to shake as much as the tacoma does while i am off road.
    The Tacoma, a 2002, shakes a bunch, prob bc of the tread on the road left by the logging trucks, but it just seems like its kinda outta hand, also seems like the stick shift shakes too, sometimes strongly, while im off road and going over bumps, potholes ect.
    is this normal, my ride was owned by folks who didnt go off road ever, and the under carriage looks flawless, fwiw
    Is all this normal? Is there anything I can do to make driving to work, everyday back and forth for miles, on these roads more comfortable, while not compromising ride quality?
    i was thinking EMU setups bc i read they make there kits for guys who have to deal with off road stuff daily.
    thanks for your input
  2. Dec 16, 2013 at 9:15 PM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    I see in your truck has the TRD package. In addition to the e-locker, it also comes with stiffer springs.
    I suppose what's really going on here is that your Ford Ranger was much less of a truck and more like a car :/
    Things that could improve your ride quality on those bumpy backroads:
    Going slower
    Ask them to pave it
    Avoid the bumps
    Get new tires with more sidewall
    Swap out your springs for softer ones
    Get new shocks
    Putting some weight in the bed might help
    Ever heard the phrase "rides like a truck"? Well...you bought a 4x4 off-road machine. Enjoy.
  3. Dec 16, 2013 at 9:18 PM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    Your suspension is probably all stock? How many miles? Might be time for a upgrade new shocks front springs and rear leafs.
    Old man emu is a good setup,
  4. Dec 17, 2013 at 8:22 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    This could be a bad motor mount (there are 2 under the motor, and one under the tranny). Have these checked out.
  5. Dec 17, 2013 at 8:27 AM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    How many miles are on your shocks?
  6. Dec 17, 2013 at 8:30 AM
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    What PSI are you running in the tires?
  7. Dec 18, 2013 at 6:20 AM
    530to707
    NorCal
    Hey guys,
    So yeah I realize its an off road machine, but i have been in yota before and they seemed a bit more soft over the bump. Maybe not
    my rig has 130k miles
    im going to check the tire pressure but they are not too full i know that..
    thanks for the input guys and ill report back with somemore info.
    Its not that i didnt expect the truck to work like a truck, thats why i got it and thats why i work with it, I just didnt expect the shifter to shake so much, Im gonna have the motor mounts checked out, as i have a subaru 5spd that on the same roads is as bumpy, but doesnt shake the stick
  8. Dec 18, 2013 at 8:15 AM
    fast5speed
    Washington D.C.
    Shifter movement could be a motor/trans mount issue, or it could just be a semi-worn shifter ball. My 94 Hardbody has as much lateral shifter movement in gear as most new cars have in neutral. Only 150k on it. The shifter ball has worn out of clearance slightly over 20 years. Same with my Honda. But that has a linkage. Only difference is the shifter bushings can wear and cause play and slop in the shifter.
    I definitely recommend inspecting yours mounts, but I would think you would have noticed a shot motor mount earlier. If you have a broken mount, and you floor it, your whole motor will rotate, especially on the v6s. I've seen cases were v6s put dents in the hood. And your shifter will also move significantly while accelerating.
