Heavy vibrations
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomathunder, Dec 22, 2014.
  1. Dec 22, 2014 at 7:51 PM
    tacomathunder
    tacomathunder [OP] Well-Known Member
    Florida
    07 4 cyl reg cab
    pop-a-lock on tailgate, tailgate damper by ez down, extang platinum snap tonneau cover, rampage LED light bar, etrailer wiring harness, black led tail lights, tsi clutter catcher center console, griffin itrip ipod player,BHLM,35W DDM Tuning hid's 5000K, Day Time Running Light Mod, New Sony Stereo
    I'm experiencing heavy vibrations between 2nd and 3rd gear, and a delay in shift from 3rd to 4th... Plus a weird chirp coming from the front of the truck. Anyone have any ideas? If it's the transmission, is there a recall for something like this that toyota will fix for free? Nervous because I just moved out and have a ton of bills to pay, don't need another one coming
  2. Dec 22, 2014 at 9:34 PM
    Pavlovsdog
    Pavlovsdog Active Member
    Tampa, FL
    07 PreRunner 2WD
    Ujoints
  3. Dec 23, 2014 at 1:44 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Yup, check your ujoints. Most shops would fix it for about 100 bucks or so
  4. Dec 23, 2014 at 2:42 AM
    MPToyo17
    MPToyo17 Member
    Mark
    Coconut Creek
    '05 PreRunner
    I had the same issue, just had U-joints and carrier bearing replaced on my '05. 104,000 miles
  5. Dec 23, 2014 at 4:07 AM
    tacomathunder
    Florida
    07 4 cyl reg cab
    Just curious as to how it's the u joints if the vibrations stop when I release the accelerator?
  6. Dec 23, 2014 at 4:21 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'll give it a shot....
    When you're accelerating - the driveshaft and/or pinion (at the rear diff) pivots upwards due to the torque. This is why Ujoints exist - because there is constant movement in the driveshaft as you drive. When you release the accelerator - the driveshaft / pinion drops.
    Depending on the extent of the Ujoint failure - you can get all sorts of different symptoms at different times.
    You should crawl under the truck and inspect the Ujoints for obvious wear. When was the last time your driveshaft was lubricated? If you can't remember....lubricate the ujoints NOW. You'll know soon enough after lubricating them, if you hit the bullseye. Its all a part of troubleshooting.
  7. Dec 23, 2014 at 6:00 AM
    Pavlovsdog
    Tampa, FL
    07 PreRunner 2WD
    I'm not positive, but I don't think the 4 cylinder regular cab Ujoints have zerk fittings. If there aren't just see if there is any play at all in any of the ujoints. If there is, that's you're problem.
    ...the good news is this is a cheap fix at a local mechanic...and some will tell you easy to do yourself (but a little much for me, personally).
  8. Dec 23, 2014 at 6:11 AM
    tacomathunder
    Florida
    07 4 cyl reg cab
    Just had it looked at and you guys were alright it is that you joints but the shop wanted $500 to fix it for parts and labor and then my girlfriends dad called because he is a mechanic and he knows the owner and I dropped it down to 200
