Heim Joint Rod End
Discussion in 'Technical Chat' started by Taylorbarton1, Jan 5, 2020.
  1. Jan 5, 2020 at 8:01 AM
    Taylorbarton1
    Taylorbarton1 [OP] Well-Known Member
    Taylor
    Hotlanta
    2011 TRD off-road
    6 inch lift. 35's.
    Here is the deal, the taper on my spindle is wallowed out and my solution is to drill the taper out and bolt on a female heim joint with misalignment spacers. Anyone ever done this?
    I've got a drop bracket lift with aftermarket spindles so purchasing a new spindle is a bit out of the question.
    The link below is for the type of heim I am looking at.
    https://www.motionindustries.com/productDetail.jsp?sku=06464550
  2. Jan 5, 2020 at 3:20 PM
    Taylorbarton1
    Taylor
    Hotlanta
    2011 TRD off-road
    6 inch lift. 35's.
    no one here has ever experimented with heim rod ends? :confused:
  3. Jan 5, 2020 at 6:46 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Are you replacing the tierod end with this?
  4. Jan 5, 2020 at 6:52 PM
    Taylorbarton1
    Taylor
    Hotlanta
    2011 TRD off-road
    6 inch lift. 35's.
    That is my thought...yes. I've put hiem steering kits on a couple jeeps and an early bronco with luck. I see no reason why it wouldn't work on a tacoma, but wanted to run it by the forum first. Maybe I'm missing something.
  5. Jan 5, 2020 at 6:59 PM
    gotoman1969
    The only issue I see possibly happening is that with the tapered fit, there is zero play in the tie rod where it goes through the spindle. Once you drill out the spindle If where the bolt for the heim goes through isn’t almost like a press fit you probably will wallow out the spindle, there can be no play there that’s why they use the taper on both the ball joints and the tie rod ends.
  6. Jan 5, 2020 at 7:09 PM
    gotoman1969
    I like the idea though.
  7. Jan 6, 2020 at 2:23 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just what caused the problem in the first place??
    Has it been corrected ?
    How long was it driven with things loose ??
    Have any Cracks appeared ?
