Hella 4000 Beam Pattern Choices
Discussion in 'Lighting' started by DDD, Sep 30, 2011.
  1. Sep 30, 2011 at 8:55 AM
    DDD
    DDD [OP] Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    I am trying to decide which Hella 4000s to get. I already have a light bar with 2 Hella 500s with 55W HID conversion. I am going to add 2 Hella 4000s and convert them to 55W HID also.
    The Hella 4000 options are:
    Euro Beam
    Fog Light
    Pencil Beam
    Cornering Beam
    Below is a diagram I found on this site.
    [​IMG] [​IMG]
    Rallye 4000 Euro Beam
    [​IMG] [​IMG]
    Rallye 4000 Fog Lamp
    [​IMG] [​IMG]
    Rallye 4000 Cornering Beam
    [​IMG] [​IMG]
    Rallye 4000 Pencil Beam
    My 2 Hella 500s are more of a directional spot light. At about 50 yards they keep a pretty tight beam. So I am leaning towards Cornering beam because its a wide pattern and reaches out to 200 meters. i find that the pencil beams will be useless on a trail with tight turns. Even now the Hella 500s are not very helpful on a trail. I will be doing mostly trail driving, some rock crawling, so I won't be traveling very fast. I want to be able to see everything clearly within 100 yards.
    Does anyone have the Cornering beam, how do you like them? Will the euro beam give me a wide enough pattern?
  2. Sep 30, 2011 at 9:17 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    I have the pencil (spot) beam 4000s and recently converted the 100 watt halogen bulbs to 35 watt HID (5000K). There is a thread I made on it here on TW Lighting forum.
    Pencil beams (a pair) will light no more wide than the width of a 2 lane road, but FAR down it... So, I suggest only using them if you also have a pair of driving beams (aka euro beams)... which light up more area, much like your high beams, but brighter.
    The ultimate would be 6 lamps: 2 pencils, 2 euros, 2 fogs or cornering... For up close/ wide... mid range wide... and far range narrow.
  3. Oct 1, 2011 at 3:39 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Fog or the wide cornering pattern would be best for tighter/switchback trails.The wider the better in this case.As far as maybe using the Euro/combo light pattern,the second part of that combo is spot.You all ready have distance w/the 500's.No good for what your looking for.
  4. Oct 5, 2011 at 8:56 PM
    DDD
    Derek
    Santa Clarita, CA
    BUMP.
    Anyone here actually have the cornering beams?
  5. Oct 5, 2011 at 11:38 PM
    David K
    The conering pattern and photo you show looks awesome... please get that and show us how they work!
  6. Oct 8, 2011 at 1:35 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Perhaps one of each? Seems like most of the lightbars for these trucks are good for 3 lights, four is pretty crowded looking.
    I am planning on a pair of euro beams when I get the money.
  7. Oct 8, 2011 at 2:58 PM
    David K
    If just one pair, the driving (euro) beams on a bar or bumper would be best... The best place for fog beams is low, below the bumper, so that is where 2 of the 6 would go... leaving room for 4 on the bar.... the 2 driving and 2 spot beams. Even better are spots on on the roof.
    Anyway... some are better than none!
