Hella 500 Black Magic wiring kicking my A$$...
Discussion in 'Lighting' started by trdchic, Dec 25, 2012.
  1. Dec 25, 2012 at 4:03 PM
    trdchic
    trdchic [OP] Well-Known Member
    Erie CO
    07, TRD Sport, 4x4, SR5, V6, Access Cab
    I am TRYING to install these damn lights and cannot get it to work. Tested the lights by bypassing everything and they turned on so that's promising. Blew one of the fuses but figured that out so replaced it...yay. Right now trying to determine if the switch is bad. It looks like it should light up but even attached directly to the battery it doesn't... should it?
    I am also trying to avoid messing with the headlights so I bypass them and connect directly to the battery.
    Blue from light is grounded to the frame. Black from light to relay. Red from relay to positive side of battery. Blue from relay grounded to the frame. Yellow from relay to center of switch (there are 3 spots). The other two spots on the switch are grounded to the frame (under the steering column) this is attached to the "line" side (the on position). The other end (the 0 ) has a green going directly to the positive battery terminal (bypassing the headlight).
    I am at a loss here...please help!:mad::confused:
    Look at the attached PDF of the instructions... what is the white box between the relay and the battery in the picture???
  2. Dec 25, 2012 at 4:08 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    The white box is a fuse I believe.
    Run the grounds off the lights to a ground, splice the positive together and run them to the relay. Run power to the relay, run ground to the relay. Run a switch to the relay and then a 12v power source to the switch.
  3. Dec 25, 2012 at 4:24 PM
    trdchic
    Erie CO
    Interesting...did you confuse the 85 ground and the 86 to the switch? On the instructions from Hella they are opposite to wha you show... does it matter? How can I test the fuses and switch to see if wither of them is my problem?
  4. Dec 25, 2012 at 4:30 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Right now, you have a short to ground. The only way to blow a fuse is to short your circuit out. Trace your wiring, clearly you have something backwards. Even if the switch is bad, as long as its wired correctly, you won't blow a fuse.
  5. Jan 2, 2013 at 10:44 AM
    trdchic
    Erie CO
    They work!!!!!!!!!!!!! Thank you for the help
  6. Jan 7, 2013 at 12:03 PM
    xgalvanxgx
    xgalvanxgx seymour butts
    Gerardo
    OC (Lake Forest) California
    TRD Off-Road BlackSandPearl 07 PreRunner
    DTF Race Kit with 2.5 x 10 Kings, DMZ SUA rear with 16" triple bypass Kings, King bumpstops front and rear, 17" KMC RG1 powdered in Matte Bronze with black ring with 37" BFG KO2s, front and rear DTF bumpers, front Fiberwerx glass and Mcneil trophy bedsides, K&N 77 Series Intake, Magnaflow, Pioneer touchscreen, Rockford Fosgate 10" sub with box and amp. Dyanamat walls, Andres' devil horn emblem, 50" D4 curved LED bar, rear chase light rack (brake, ambers, white lights) Engine brace, deleted inner wheel wells for max up travel. Cab roll rage built into bedcage.
    ello! i have 4 Hella Rallye 4000s and my concern is are these babies too powerful to run on my battery? i got a good deal on them so i took them.
