Hella 500 HID Conversion
Discussion in 'Lighting' started by NwiTACO, Jun 11, 2009.
  1. Jun 11, 2009 at 9:26 AM
    NwiTACO
    NwiTACO [OP] Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    OK, so I know lots of you have Hella's on your trucks. I'm not sure, but I don't really think I'm the only one who is dissappointed by the light output. I have a set of driving lights and a set of fog lights so I got two 35W, H3, 4500K HID Conversion kits.
    http://www.ddmtuning.com/index.php?p=product&id=102&parent=85
    Not the easiest conversion, I made it harder than it need to be, but I wanted it to look factory, and it does.
    First the reflector assembly must be removed from the housing.
    Then, due to the new bulb's added insertion length, you need to remove the lamp holder from the reflector assembly. This is done by straightening the three (3) tabs on the back.
    Once removed, remove the inner portion of the lamp holder.
    Re-insert the lamp holder, and bend the tabs back.
    The main portion of the lamp wiring looks like this:
    You are supposed to drill a 7/8" hole for the grommet so the wiring can enter your housing. I though it was kinda dumb to leave the stock power entering the housing, then have another grommet bring the power to the lamp from the ballast, as well as the new power wires to connect right to the old power wires inside the light. I wanted two wires entering the housing only, going to the bulb so here is the mod's to do so.
    First remove the grommet from the wiring harness. Cut down the grommet to each wire. When you are done the grommet will look like this.
    Now the back portion of the bulb is too long to fit in the housing when installed within the reflector. To rectify this, simply take a dremel and grind a relief down the side of the bulb so the wires can exit the side like this (Note: the lamp is still in the protective case at this time to protect the bulb):
    Next remove the grommet from the original wiring for the Hella's.
    Now grind off the bosses inside housing to make adittional room within the housing. It should look like this when you're done.
    Now enlarge the wire entry hole so the plugs on the bulb can fit through the hole.
    Install reflector assembly back in the housing, install the factory grommet around the new wires, add silicone to help seal up the entry of the wires.
    Now the assembly for one light looks like this:
    Simply hook up the red and black and your in business!
    Now repeat for the other fog light...then the other two driving lights...and whollah:
    (insert completed re-installed photo of lights on truck here) :D
  2. Jun 11, 2009 at 9:54 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    Nice write up. Thanks
  3. Jun 11, 2009 at 2:06 PM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    You are very welcome, sir.
  4. Jun 11, 2009 at 3:47 PM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
    great install, lets get some pics of the lights on now:D
  5. Jun 11, 2009 at 4:26 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    I think your camera's focus function is broken.
  6. Jun 11, 2009 at 7:57 PM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    It's fine, I just shake a little bit and it makes it hard for the camera to focus.
  7. Nov 22, 2009 at 5:33 PM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    so how much brigher are they now. i'm thinking about doing this soon and am wondering if it is really worth it
  8. Nov 22, 2009 at 5:43 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Edmonton AB
    07 2wd access cab base.
    Sold the ol girl
    so all you need to power these HID's is a + and -?
    is all hid's like this or am i not seeing this correctly?
  9. Nov 22, 2009 at 8:15 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    To power HIDs, you need ballasts. They are little boxes that convert power to the HID capsules.
  10. Nov 22, 2009 at 8:38 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Would it be okay to run 6000k conversion on Hellas?
  11. Nov 22, 2009 at 8:39 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Yea you will have no problem with the 6k.
  12. Nov 22, 2009 at 8:41 PM
    neslerrah
    Harrelsen
    Tucson
    5 lug BEAST!
    Sweet! Thanks!
  13. Feb 23, 2010 at 6:18 PM
    Cars0n`
    Carson
    Edmonton AB
    Sold the ol girl
    does it really make much difference with the 35w kit vs the 55w kit? my friend told me the 55w does not put out much more light than the 35w kit.
  14. Feb 28, 2010 at 5:42 PM
    Cars0n`
    Carson
    Edmonton AB
    Sold the ol girl
    anyone know this?
  15. Feb 28, 2010 at 8:43 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    i've never seen anyone with the 35w kit but i know my 55w kit is brighter than hell. from half a mile away looking at them it blinds you still. its pretty ridiculous how bright they are
  16. Feb 28, 2010 at 10:05 PM
    Cars0n`
    Carson
    Edmonton AB
    Sold the ol girl
    are you referring to a hella conversion or in your headlights? also if in the hellas what beam pattern do you have?
  17. Mar 1, 2010 at 7:08 AM
    Cars0n`
    Carson
    Edmonton AB
    Sold the ol girl
    must have missed that, thanks man! :thumbsup:
    if i get the 500's can i use the 55W kit in them? im concerned about them getting too hot. has anyone done this or know of the effects?
  18. Mar 1, 2010 at 7:11 AM
    NwiTACO
    Mark
    Indiana
    05 TRD Sport
    You should n't have a problem with heat, and they will fit as long as the bulb is the same size bulb.
  19. Mar 1, 2010 at 7:19 AM
    Cars0n`
    Carson
    Edmonton AB
    Sold the ol girl
  20. Mar 1, 2010 at 10:13 AM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    i have 55w in my head lights and hella's. my headlights aren't that great though cause i had to buy new housing's that would fit the h4 bulbs and i went cheap and got two housings off ebay for 20 bucks :p so i need to get better ones and then im sure they will be brighter. in the hella's the beam patttern is hard to explain. it defenetly has bright spots but overall they put out WAY more light than stock hella's. ill try and snap a picture of them on tonight and post them on here.
