hella 500 instructions suck
Discussion in 'Lighting' started by stevenstaco, Mar 9, 2011.
  1. Mar 9, 2011 at 4:20 PM
    stevenstaco
    stevenstaco [OP] B A N N E D
    steven
    sacramento ca
    o7 trd sport sr5 4x4/06 4runner sr5 4x4
    1.5 aal,Tacomaworld sticker,Blacked out tail lights,bhlm,.dumped exhaust,relocated 7 pin ,rear diff breather mod,bed lights,hella 500s behind the grill,plastidipped lower vallance,mag light mod,debadged,black billit grill,bedmat mod,airaid intake,vynil armrests and back rests,tailgate theft mod, ipod interface,backseat cargo mod,front 5100s
    so one of the wires from the switch needs to be spliced in with red ??
  2. Mar 9, 2011 at 4:23 PM
    jblaze805
    jblaze805 Well-Known Member
    Ventura/Fresno, CA
    04 trd pre-runner
    2.5" king coilovers, caburg uca, magnaflow exhaust, aem intake
    sorry have it go straight to the batt. am updating the pic right as we speak
  3. Mar 9, 2011 at 4:26 PM
    stevenstaco
    steven
    sacramento ca
    so 2 wires to the battery
  4. Mar 9, 2011 at 4:26 PM
    jblaze805
    Ventura/Fresno, CA
    04 trd pre-runner
    updated....yes
  5. Mar 9, 2011 at 4:31 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    No! Blue wire is ground... It needs to be grounded to the truck somewhere. Red for the relay and green for the switch are the only wires that are hot and should be the only ones connected to the battery. The black wire from the relay should connect to the positive for the lights.
    On the switch... Ground prong 3. Connect prong 2 to pin 86 on the relay. Connect prong 1 to the battery.
  6. Mar 9, 2011 at 4:36 PM
    stevenstaco
    steven
    sacramento ca
    :(i think i got some defective lights
  7. Mar 9, 2011 at 4:41 PM
    memario1214
    Colton
    Missoula, MT
    Test them. Touch the positive wire of the light to the positive post of the battery. Touch the negative part of the light to the truck somewhere to ground it. Should come on
  8. Mar 9, 2011 at 4:41 PM
    jblaze805
    Ventura/Fresno, CA
    04 trd pre-runner
    still nothing, dang....hmmmm i know this might sound dumb but have you checked the bulbs to see if they are burnt out????
  9. Mar 9, 2011 at 4:44 PM
    stevenstaco
    steven
    sacramento ca
    yeah there brand new :confused:
  10. Mar 9, 2011 at 4:44 PM
    jblaze805
    Ventura/Fresno, CA
    04 trd pre-runner
    def a quick way to check if its the bulbs or not
  11. Mar 9, 2011 at 4:48 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    yea to test them just take the light, put the red wire to positive battery teminal and black wire to negative terminal. if it lights up the lights are good, if not, then take them back.
  12. Mar 9, 2011 at 4:55 PM
    stevenstaco
    steven
    sacramento ca
    ok thanks ill have to tackle this again
  13. Mar 9, 2011 at 5:03 PM
    JLink
    Josh
    Ocean, NJ
    yea and you dont actually have to use the relay to wire them up anyway.. I have 2 hella 700ff's that i converted to HID and I'm not using a relay. I have a factory fog light switch so that complicates it a little, but just run a wire from positive terminal on the battery to an in line fuse and from the fuse to the power input terminal of the switch, then a wire from the power output terminal to the red wire on the lights. ground the black wire from the lights to some metal on the truck.. usually you can find a bolt somewhere near the lights that you can loosen up enough to slip the wire into and then tighten the bolt back up. or you can even just run the black wire on the light all the way back to the battery and attach it to the negative terminal
  14. Mar 9, 2011 at 5:06 PM
    stevenstaco
    steven
    sacramento ca
    yhanks for all the help like i said ive wired lights before but these just arent workin for me ill give it a try tommorow with out the relay ..........i like the kayak set up
  15. Mar 9, 2011 at 5:57 PM
    #35
    memario1214
    Colton
    Missoula, MT
    You can run it without a relay, but it is very stupid to do... I highly suggest that you put a relay in. You are running power through the switch itself, which is not meant to handle much power at all (just enough to light the switch). I can attest to this problem. In my infinite knowledge :rolleyes: I wired up my lights just like you have yours. This last fall, I was driving back home from hunting, and the energy and heat travelling through my switch eventually made the switch fail. This failure led to the switch exploding and starting a nice little fire in my cab (given it was just the switch and the wires burning, but still, this could have been a bigger problem). I have since fixed the issue. Do yourself a favor. Get yourself some cheap insurance and put in a relay.
  16. Mar 9, 2011 at 6:09 PM
    #36
    JLink
    Josh
    Ocean, NJ
    ^ depends on what voltage your switch is rated to. If your switch is rated at 12 volts then there is no problem. You just overloaded the switch.
    Good point though.
  17. Mar 9, 2011 at 6:15 PM
    #37
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Groung the 2 black wires coming out of the lamps, run a wire from one lamp to the other, then run that one to the switch, then run a wire from the battery to the switch
  18. Mar 9, 2011 at 8:45 PM
    #38
    stevenstaco
    steven
    sacramento ca
    so 86 splices into 30? and everyone says ground the black which is what i always thought too but the instructions say ground the blue wires
  19. Mar 9, 2011 at 9:24 PM
    #39
    kinkrider101
    santa barbara
    wheels and tires
    If itSays ground blue, then ground the blue, but black wires usually refer to a ground
  20. Mar 9, 2011 at 9:28 PM
    #40
    stevenstaco
    steven
    sacramento ca
    thats how i wired my last ones then i ripped those out and was gonna use the relay that came with the lights ill figure it out tommorow thanks
