hella 500 instructions suck
Discussion in 'Lighting' started by stevenstaco, Mar 9, 2011.
  1. Mar 9, 2011 at 9:41 PM
    #41
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Bingo... this is the correct way to wire this (switch simply interupts ground)
    The only thing I would change is to tap 86 into something that only is hot when the key is on. That way your lights turn on off when the truck turns off... also a small fuse in the coil circut.
  2. Mar 9, 2011 at 9:43 PM
    #42
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Mayne you switched the ground a the power wires on the lamps
  3. Mar 10, 2011 at 10:09 AM
    #43
    stevenstaco
    stevenstaco [OP] B A N N E D
    steven
    sacramento ca
    o7 trd sport sr5 4x4/06 4runner sr5 4x4
    1.5 aal,Tacomaworld sticker,Blacked out tail lights,bhlm,.dumped exhaust,relocated 7 pin ,rear diff breather mod,bed lights,hella 500s behind the grill,plastidipped lower vallance,mag light mod,debadged,black billit grill,bedmat mod,airaid intake,vynil armrests and back rests,tailgate theft mod, ipod interface,backseat cargo mod,front 5100s
    ok the saga has ended... i did not use a relay but ran the power wire with a fuse. for some reason the switch that came with the lights did not work:confused: i used a switch i already had and it worked perfect ....thank you everyone for the diagrams and helpful tips... i was going crazy cause ive hooked up lights before and never had a problem but am no electrical genius lights 005.jpg
  4. Mar 10, 2011 at 10:23 AM
    #44
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Glad you got it to work! :thumbsup:
  5. Mar 10, 2011 at 10:34 AM
    #45
    stevenstaco
    steven
    sacramento ca
    haha me too
  6. Apr 10, 2011 at 11:04 PM
    #46
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Im having problems with mine too. My lights just click when I turn them on, but the light switches that came with the hella kit dont light up, are they supposed to? When I test the lights they just click, they are brand new any ideas? Sorry to jack your thread.
  7. Apr 10, 2011 at 11:14 PM
    #47
    stevenstaco
    steven
    sacramento ca
    I ended up not using the relay
  8. Feb 18, 2017 at 5:05 PM
    #48
    themanbearpig012
    themanbearpig012 Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    Love the set up gonna do the same for my rig. One question though.. What kind of bulbs do you have in your headlights and fog lights?
  9. Feb 22, 2017 at 9:22 AM
    #49
    Gasturbine
    Gasturbine Well-Known Member
    Central Ohio
    2011 Regular Cab 2.7l 5-speed 4WD
    32" BFG KO tires on MT rims, Front lifted 2", N-Fab 12,000lb front pull point w/10,000lb red clevis, mud flap delete, tail pipe delete, 20" LED light bar, 2 Hella 500s, N-Fab light bar mount, tinted windows.
  10. Feb 24, 2017 at 5:30 AM
    #50
    Gasturbine
    Central Ohio
    Also, Hella is German...black wire is hot, while blue or brown is ground.
