hella 500 question
Discussion in 'Lighting' started by taco2408, Feb 26, 2010.
  1. Feb 26, 2010 at 9:08 PM
    taco2408
    taco2408 [OP] Well-Known Member
    Marcos
    San Antonio, TX
    08 PreRunner DoubleCab
    Okay, I just got this kit and I'm trying to figure out what is meant by connecting the green wire to the high beams. How do you do this? I know this may be a dumb question but I definately haven't wired lights before. Any help is appreciated. Also, do I have to ground the two lights and if so what are some good spots to ground them. THanks.
  2. Feb 26, 2010 at 9:28 PM
    CopDoctor
    CopDoctor Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    yes you must ground them, otherwise nothing will work. you don't have to wire them to the high-beams, i actually wired them to the running lights so i always have the ability to turn them on. you have to use the little plastic coupler, its a small plastic piece with a metal blade in the middle with slots for two wires (your hot wire and the green wire), you need to put both wires in the piece and clamp it down so the wires are ecentially connected.
    as far as grounding the wires, you just want to find a good clean metal bolt with a washer to stick the wires under, if after wiring the whole thing your lights/switch don't turn on, you'll want to check the grounds first
  3. Feb 26, 2010 at 9:37 PM
    taco2408
    Marcos
    San Antonio, TX
    thanks for the response..that info helps out
  4. Feb 26, 2010 at 9:39 PM
    taco2408
    Marcos
    San Antonio, TX
    when you see hot wire you mean the wire from the running lights or high beam lights, right?
  5. Feb 26, 2010 at 9:40 PM
    CopDoctor
    Trinidad, CO
    no problem, i just installed mine a couple weeks ago and the install is still very fresh in my head so if you have any other questions just let me know...also i highly suggest wiring them to your running lights like i posted above, otherwise the only time you'll be able to turn them on is when your high-beams are on..which is next to never (that way the running lights power the switch)
  6. Feb 26, 2010 at 9:42 PM
    CopDoctor
    Trinidad, CO
    yes, exactly. your hot wire is the wire that your truck has power running through. when you turn your running lights on, your running light wires are hot. when you connect your green hella wire to your running light positive wire (make sure you don't connect it to the running light's ground wire) the power is also sent to your switch. when power is sent to the switch, you have the ability to turn on/off your lights. when your running lights are off, your hellas will be off no matter what since the circuit has no power going into it at all
  7. Feb 26, 2010 at 9:46 PM
    taco2408
    Marcos
    San Antonio, TX
    ok, but i'm still a little confused. how do you take the hot wire out of the running lights to put into the coupler and where does the coupler go..i hope this is not too dumb of a question..i know i can do this if I understood this part.
  8. Feb 26, 2010 at 10:01 PM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    I didn't connect mine to the headlights or running lights at all. I just connected the black ground wire to the frame (using a self tapping screw and a drill, l I tapped it into the sheet metal). The red wire goes to a switch in my cab and then to the positive terminal on my battery.
  9. Feb 26, 2010 at 10:15 PM
    CopDoctor
    Trinidad, CO
    the wire splice should look like this::
    http://www.supermotors.net/getfile/561868/fullsize/wire-tap.jpg
    the long wire on the left is your "hot" wire. you just clamp it on anywhere on the wire on a free space then your green hella gets put in there as well
  10. Feb 26, 2010 at 10:17 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    exactly what i have done for all of my lights...that way the truck doesn't even have to be on to use your lights...i do recoment using a switch that lights up when on though, so you don't forget them and kill you battery.
  11. Feb 26, 2010 at 10:21 PM
    CopDoctor
    Trinidad, CO
  12. Feb 26, 2010 at 10:22 PM
    CopDoctor
    Trinidad, CO
    last time i did that on my old truck i left all my lights on and ran the battery out...like a hundred times lol
  13. Feb 26, 2010 at 10:33 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i did the same thing lol...so i swapped all of my switches out for illuminated ones, and haven't done it since
  14. Mar 2, 2010 at 9:51 PM
    taco2408
    Marcos
    San Antonio, TX
    Okay, I was trying to do this today and I just have a few questions. What color is the hot wire from the driving lights. I saw a green wire and a white wire? Second, can I ground the lights to the bull bar itself? And lastly, where did you ground the wire from the switche itself? Any help would be appreciated. Thanks.
  15. Mar 2, 2010 at 10:23 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    not sure which wire is hot based on those colors, green maybe???
    you could ground it to the b ull bar, but i like to ground mine in the engine bay where they are less exposed to the elements. as for the switch, you can run the ground for that back through the firewall and ground it in the engine bay as well, or just find bold under the dash near somewhere near the firewall.
  16. Mar 3, 2010 at 9:27 AM
    CopDoctor
    Trinidad, CO
    green. ground to the bull bar? might work, might as well give it a shot. if things don't work check that first. where to ground the switch wire? brake pedal bolt is where i did mine :anonymous: there's also a bolt right behind the plastic next to all the fuses and such, i couldn't get to it and didn't want to tear apart the truck for a wimpy ground wire
  17. Mar 3, 2010 at 10:46 AM
    taco2408
    Marcos
    San Antonio, TX
    thanks matt..i was going to ground it to the brake pedal bolt but I wanted to see what others had done.
