Hella 500f's won't turn off
Discussion in 'Lighting' started by Gengle07, Aug 2, 2012.
  1. Aug 2, 2012 at 12:00 PM
    Gengle07
    Gengle07 [OP] Active Member
    Greenville, SC
    08 TRD Off-Road Rugged Trail 4x4
    Avid Offroad Light Bar Baja Rack Roof Rack 42" LED Lightbar ARB 6' Awning ARE Z-Series Shell Custom Bed Drawers OME Suspension 1.5" All-Pro Wheel Spacers BFG 285/75R16 All-Terrain KO2's Diff Breather Mod
    I've searched numerous threads for this issue but most deal with not turning on do to poor ground or bad relay etc. I've wired my driving lights with a lighted switch and spliced into the parking lamps so they are only available when the main light switch is turned on. When I first installed them they worked flawlessly: turn main light switch (park or lowbeam), driving light switch lights up, toggle switch, Hellas illuminate. Now however, whenever I turn the main light switch, the Hellas come on whether its switch is toggled or not and wont turn off until the main/park lamps are off. If I tap the relay they will turn off but I've replaced this with a new Autozone relay and same thing. Any ideas? Is the current from the park lamps too low to throw the relay? Any help is appreciated.
  2. Aug 2, 2012 at 12:12 PM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Maybe the lighted switch has a high resistance short in it. It might allow just enough current to keep the relay closed until you tap it. Pull the switch out and turn the lights on then off, if the lights stay on cut one of the wire to the switch. If the lights go out change the switch.
  3. Aug 2, 2012 at 12:21 PM
    Gengle07
    Greenville, SC
    Thanks I'll look into the possibility of a faulty switch.
