Hella Black Magic
Discussion in 'Buy / Sell / Trade' started by Rustyrooster, Oct 14, 2009.
  1. Oct 14, 2009 at 2:50 PM
    Rustyrooster
    Rustyrooster [OP] Well-Known Member
    Decatur Tennessee
    O9 Tacoma TRD Sport Black Sand Pearl
    TRD High Performance Exhaust, Satoshi Grille, 3 inch Revtec Lift, Pioneer avh-4100dvd,Retrax bed cover
    Wanting to find best price for Hella BM Lights or buy a good used set
  2. Oct 14, 2009 at 4:30 PM
    Slvr_DblTaco
    Slvr_DblTaco Well-Known Member
    Chicago's western suburbs
    08 Tacoma DblCab Sport PreRunner
    new grill, black headlight mod, tinted front glass, ToyTec coils overs, 33" nittos for winter, 33" BFGs for summer, Metra iPod adapter
    hey there, your grille looks great... except for those horns!
    maybe try relocating then like I did...
    you'll move them almost straight down and use the bolt for the trans cooler. both horn brackets will slide onto this one bolt, and then the bolt will go right back into place holding up the trans cooler. this way the horns are still up front so everyone can hear them - but they are hidden by the large bumper cover area.
    Truck looks good man - keep me posted in pricing for those Black Magic's??
    thanks,
    Bob
  3. Oct 14, 2009 at 4:43 PM
    Rustyrooster
    Decatur Tennessee
    Thanks Just havn't got around to moving horns but plan on doing that soon will post pics
  4. Oct 14, 2009 at 6:52 PM
    Carone
    Carone Well-Known Member
    NOR CAL
    LOOK HERE!!! 02 TRD xtra cab v6 4x4 white
    Look at my Build
    same here
  5. Oct 15, 2009 at 7:17 AM
    Slvr_DblTaco
    I didn't have to cut/splice any wires - but I did have to relocate one plastic clip thingie.
    If I remember correctly, there is this small black plactic thing that is mounted to the vertical support in front of the radiator. Pop that out and simply wedge it between the drivers side of the trans cooler and the support that the trans cooler is mounted to. The trans cooler will be loose because the bolt was taken out to slide the two horn brackets in.
    I did have to loosen and realign the horn brackets on the horns themselves. It was a slight adjustment so both horns so they will sit flat and all mount up with one bolt...this was easy though - loosen the screw a bit, rotate one horn a few degrees and your good to go.
    Hope this makes sense.
  6. Oct 16, 2009 at 6:16 AM
    Rustyrooster
    Decatur Tennessee
    After Relocating Horns (Thanks for the help)
  7. Oct 16, 2009 at 6:20 AM
    Slvr_DblTaco
    Right on! Piece of cake huh?
  8. Oct 16, 2009 at 3:04 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    just so you know the black magics use h2 bulbs which are hard to find. i have yet to see a hid kit for a h2 bulb and theres not much out there for brighter silverstar style lights. just something to keep in mind i didn't know this till after i got mine and now i want to switch to hids so i'm going to try and use an h3 kit with a spacer in the back to see if i can make it work.
  9. Oct 16, 2009 at 6:11 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I really like the black Magics, they would be perfect for behind a Satoshi. *put on my future mod list*
