hella hid question
Discussion in 'Lighting' started by JR616, Feb 4, 2011.
  1. Feb 4, 2011 at 10:00 AM
    JR616
    JR616 [OP] Well-Known Member
    JAMES
    SOCAL
    06 double cab prerunner
    i just got a new set of hella 500's and was wondering if i do the hid mod how would i connect the switch? would i use the standard relay? i want them to be able to go on whenever i want not just with the high beams.
  2. Feb 5, 2011 at 6:41 AM
    jward2331
    jward2331 Well-Known Member
    Fleming Island, Fl
    '08 PreRunner SR5 TRD Sport
    Debadged, tinted windows, upper/lower Grillcraft (horns relocated), Hella 500's with HID Mod (55W 5000) behind grill, shorty antenna, WeatherTech side window deflectors, suspension TSB, Westin Signature Nerf bars, JVC KD A-615 Head Unit with Sirius Direct tuner, Blacked out headlights, DTDL Mod (Switch for on/off), Hard Wired GPS, NOKYA Arctic Hyper Yellow Fog lights, Fog lights on anytime Mod, Michelin LTX M/S2 (P265/65R17), Powder coated OEM wheels. LED ANZO tail lights, Weather Tech FloorLiners.
    Hella's instructions say to tap into the low beam light wire. I tapped into the fuse panel under the hood using a "hot all the time" fuse. It's crappy out there right now and I don't have the info right in front of me.
    Your other question is about the relay. Wire the rest of they system as spelled out in the instructions (there are plenty of links with pics to follow on here, just do a "Search" on the forum. There is also a thread on how to mod the hella,s with HID. I just ordered my HID kit and anticpate it gettime here on the 10th.
    To do the HID install:
    search "Klipp11" it's probably the first post you see by doing that search.
    http://www.tacomaworld.com/forum/li...nversion-mount-behind-satoshi-how-w-pics.html
    Search the forum for a "How to" or "DIY" to install the Hella's, not sure of yor doing them on a light bar or behind the grill.
    Good luck. PM if you have more questions
  3. Feb 5, 2011 at 6:48 AM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    I made Hella 500 into HIDs with DDM kit....
    I used a relay, and powered the lights through my aux fuse box. but if you don't have one of those, then you can go straight to battery. The HID kit draws more than standard 500s....
  4. Feb 15, 2011 at 9:58 PM
    Average JOE
    Average JOE Well-Known Member
    San Diego
    PreRunner
    3'lift,Upgraded sound system,Dyanamat interior flowmaster,K&N,
    Do you know how much more power they draw?
