Hella Horns? Who loves what?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Col4bin, Jul 21, 2021.
  1. Jul 26, 2021 at 3:02 PM
    wolf2600
    wolf2600 Well-Known Member
    San Jose, CA
    2021 TRD-OR 6MT-SOLD
    Coyoza Tuned
    On my WRX, I went with the "sharp tone" Hellas.
    Sounded pretty good.
    Doobfucious likes this.
  2. Jul 26, 2021 at 8:23 PM
    Col4bin
    Col4bin [OP] Well-Known Member
    Maine
    2018 TRD OR Double Cab
    So how TF you figure out which is the pos terminal and which is the neg terminal on the Hellas? Talk about annoying!
  3. Jul 26, 2021 at 9:03 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I just assumed the case was negative/ground and connected spade terminals to the positives.
  4. Jul 27, 2021 at 11:02 AM
    Col4bin
    Maine
    on the stock horn, yes. It only has one connector off the back of the horn. but hella has both and neither is marked. Maybe it doesnt matter lol. ill try that route, its fued for a reason LOLOLOL
  5. Jul 28, 2021 at 1:31 AM
    TacomaRoy
    TacomaRoy Well-Known Member
    Roy
    2021 Tacoma SR
    Are you guys adding a relay Or are you just Wiring these to the factory set up.
  6. Jul 28, 2021 at 3:37 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    Relay. You need to get power directly from the battery for these horns. Plus the OEM horn circuit will not provide enough juice to get the full effect from the Hella's.
    You can use the OEM horn circuit (positive) to trip the relay for the Hella's. That's what I did.
    Also have a PA speaker for my CB mounted in there. So I can cuss wayward Neanderthals out after I blast 'em with the horns....
    Benny blanco likes this.
  7. Jul 28, 2021 at 6:13 AM
    Col4bin
    Maine
    Inteteresting. On all the TW threads including a bunch of YouTube, stuff everyone said there was plenty of electrical power to run these off the stock harness. Not sure the relay is needed.
  8. Jul 28, 2021 at 9:11 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    Supertones here.
    Relay it or don't bother installing them.
  9. Jul 28, 2021 at 9:17 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    I use the factory wire to trigger a relay. Left the factory harness in place and added a return wire plus the new supply wires.
    pinochle likes this.
  10. Jul 28, 2021 at 9:21 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Not needed but they do work better with than without. Since the whole point is to get more it doesn’t make much sense to throttle it with the stock wiring.
  11. Jul 28, 2021 at 9:47 AM
    Col4bin
    Maine
    Can someone explain how to wire this with the relay? I’m up and running without the relay but I’ve got a db meter so wtf. I’ll do a test for us
  12. Jul 28, 2021 at 9:50 AM
    Col4bin
    Maine
    And by “work better” assume you mean louder?
  13. Jul 28, 2021 at 10:01 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Yup, better wiring means less resistance and higher voltage/more current. Many use 4 horns instead of 2.
  14. Jul 28, 2021 at 10:07 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    For a 4-pin relay:
    Pin 30- fused source(battery or aux fuse panel)
    Pin 87- out to horns wired in parallel with ground to either chassis or dedicated ground return to battery.
    Pin 85- disconnect all stock horn wires and extend one back to here.
    Pin 86- ground this to battery/chassis.
    When you hit the horn the extended stock wire activates the relay and feeds the horns through the new wire harness.
    pinochle and Col4bin[QUOTED][OP] like this.
  15. Jul 29, 2021 at 7:27 AM
    #35
    Col4bin
    Maine
    Soooo
    did 6 tests with no relay 12 feet from the decibel meter. All readings were 90db. Hella claims 115db on their paperwork.
    I tried for the life of me to understand and wire up @bagleboy drafted it for me but after three attempts I gave up.
    @bagleboy talk to me like I’m Billy Madison and I may be able to try this again this am. Fwiw this is on my TRD OR so I in fact have two stock positive leads just hanging there now, if that matters.
    TIA
  16. Jul 29, 2021 at 10:56 AM
    #36
    bagleboy
    Scott
    Norcal, Santa Rosa
    One positive gets extended back to the relay to trigger it(pin 85). Make sure you tape the unused horn wire as it still is hot whenever you blip the horn. Pin 86 gets grounded(chassis or battery -). A fused wire from Battery + to pin 30, a wire from pin 87 to one horn positive and on to the other, and ground all horns. It’s usually a misunderstanding so pics of what you did or think you did can often clear things up. I ran #12 wire and a 20A fuse(a bit overkill but also physically stronger).
  17. Jul 29, 2021 at 2:51 PM
    #37
    Col4bin
    Maine
    I’m gonna get some crayons and paper
    bagleboy likes this.
  18. Jul 29, 2021 at 3:18 PM
    #38
    bagleboy
    Scott
    Norcal, Santa Rosa
    Finger paint.
    Col4bin[QUOTED][OP] likes this.
  19. Jul 29, 2021 at 3:21 PM
    #39
    Col4bin
    Maine
    It’s true I’m
    Not smart enough for crayons yet!
  20. Jul 29, 2021 at 3:21 PM
    #40
    bagleboy
    Scott
    Norcal, Santa Rosa
    It’s really not complicated but as with anything there’s a language and terminology you have to learn just as with all of the suspension/lift mods that are done. Until all of it registers it’s like listening to an adult in a peanuts movie.
    Col4bin[OP] likes this.
