Hella Lights stopped working...troubleshooting??
Discussion in 'Lighting' started by Sig45, Jun 26, 2015.
  1. Jun 26, 2015 at 4:53 PM
    #61
    MDB Taco
    MDB Taco Well-Known Member
    GA
    ‘05 TRDOR DC
    So once you get the multimeter, put your positive probe in the bulb socket (with the bulb removed of course), and the negative probe to your ground. I can't say I'm familiar with the Black Magic sockets, but you should be able to do this without much issue.
    If you're registering 12V there, your wiring is good. If not, I would suspect that leg of wiring between the relay and lights to be bad.
    If that's not it, I would check the leg between the relay and the battery.
  2. Jun 26, 2015 at 4:55 PM
    #62
    MDB Taco
    GA
    ‘05 TRDOR DC
    Actually, you can try the multi meter this way: you should see two prongs in your bulb socket. Put the probes on the two prongs. Should work just as good. Just take care so you do not short it.
  3. Jun 26, 2015 at 5:33 PM
    #63
    Sig45
    Sig45 [OP] Well-Known Member
    Mark
    Maine
    ARGHHHH
    So I bought the multimeter and I was not getting power to the lights (I was getting power to the relay). So I removed all of the plastic covering and shrink tubing and inspected all of the wiring (both power and grounds) and connections and everything was solid. There are no breaks/scuffs in the wiring as it was protected. I then redid each connection, double checked everything AGAIN and still no power going to the lights. WTF!!!! I don't really know what else to do. Power cable from battery to Relay was good too.
    I'm at a loss.....Gremlins??
    I'll consider options tomorrow.
  4. Jun 26, 2015 at 6:00 PM
    #64
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yea I got nothing man. Sounds like even though you're getting power to the relay and It sounds like it's engaging it might just be bad and not sending power to the lights. I'd pick up a new relay and try it out
  5. Jun 26, 2015 at 6:02 PM
    #65
    MDB Taco
    GA
    ‘05 TRDOR DC
    I agree. If everything connection-wise is solid between the battery, the relay, and the lights, swap out the relay would be the first thing I try.
  6. Jun 26, 2015 at 6:37 PM
    #66
    Sig45
    Mark
    Maine
    That's my plan for tomorrow. Replace relay. If that fails, it must be a defect within the actual wire. I'll replace power & ground wires from relay to lights.
    Good times!! :annoyed:
  7. Jun 27, 2015 at 6:29 AM
    #67
    Sig45
    Mark
    Maine
    I'm goin' in! :frusty:
    If I'm not back in 2 hours....call the authorities! :thumbsup:
  8. Jun 27, 2015 at 8:03 AM
    #68
    MDB Taco
    GA
    ‘05 TRDOR DC
    Haha. Wiring. Gotta love it.
    Good luck!
  9. Jun 27, 2015 at 8:14 AM
    #69
    Sig45
    Mark
    Maine
    Replaced relay....prognosis NEGATIVE!! :frusty:
    It's got to be a bad spot within the wire. Off to NAPA for a new roll.
    Good times!!
  10. Jun 27, 2015 at 9:03 AM
    #70
    VolcomTacoma
    Jeff
    NorCal
    Ahhhhh man that really sucks, well if new wiring doesn't work, might as well burn the truck down!
  11. Jun 27, 2015 at 10:19 AM
    #71
    Sig45
    Mark
    Maine
    Halle....freakin'...lujah!!! :woot:
    It was bad wire....I replaced 1 by 1 and and it ended up being one of the ground wires (of course it was the 3rd one I checked so I replaced all four).
    All is now good in the world!
    Looks like I won't have to blow up the truck after all.....lol.
    Thanks for the tips & moral encouragement!
  12. Jun 27, 2015 at 10:22 AM
    #72
    MDB Taco
    GA
    ‘05 TRDOR DC
    Glad you got it solved! :thumbsup:
  13. Jun 27, 2015 at 10:28 AM
    #73
    VolcomTacoma
    Jeff
    NorCal
    Congrats bro!
