Hella Question
Discussion in 'Lighting' started by sambojee, Oct 11, 2011.
  1. Oct 11, 2011 at 11:27 AM
    sambojee
    sambojee [OP] Well-Known Member
    Sam
    Iowa
    2011 TRD OffRoad
    Bilstein 5100 all around set at 2.5. 1.5 AAL in the rear. 265/75/16 Hancook Dynapro MTs on Black Moto Metal 951s. Black badges. Aftermarket grill. TRD seat covers.
    Ive got Hella 500ff...i think, but i have a relay that always goes out about every 3 months and i was wondering if u could just cut it out and spice the wires together? it should still work right? what r the risks? thanks
  2. Oct 11, 2011 at 11:35 AM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    I'm no electrical expert but that does not sound like a good idea.
    It sounds like something is not right if you have relays constantly going out. You should double check all your wiring.
    Are you running all four of those lights through one relay?
  3. Oct 11, 2011 at 11:38 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Yes, you could do it that way I suppose. You'll be running the power through the switch. That happened to me this last fall because I didn't know any better. My switch failed and o found myself with a small fire in the cab... ALWAYS use a relay. If yours keeps going out, you're doing something wrong or you have the wrong relay
  4. Oct 11, 2011 at 2:03 PM
    sambojee
    Sam
    Iowa
    2011 TRD OffRoad
    Well i figured out my problem and im going to just take it too an expert to have him do it the right way, he said everything looked fine but since my relay is in my engine bay its starts to corrode
  5. Oct 11, 2011 at 2:15 PM
    memario1214
    Colton
    Missoula, MT
    My relay is in the engine bay, and I don't see it corroding any time soon. What is it exactly that is corroding? And falling apart in in 3 mos? I'm certain that my weather conditions are harder on components than the central US... I'm just confused
  6. Oct 11, 2011 at 2:24 PM
    JasoTaco
    X2
    I hope somebody is not trying to take advantage of you.
    Wiring these lights really is a simple job.
  7. Oct 11, 2011 at 2:54 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Some relays aren't meant to be exposed to the elements. If the OP bought a cheap one in an autoparts store that's meant to be in the cab, I'd bet 3 months in the engine bay would fry it. OP, that being said, it shouldn't take an expert to take out the old relay and replace it with a better one, that's a 5 minute job unless you found something else wrong...
