Hella Rallye 500 led
Discussion in 'Lighting' started by B1ackstar, Oct 10, 2018.
  1. Oct 10, 2018 at 6:17 AM
    B1ackstar
    B1ackstar [OP] Well-Known Member
    Burbank, CA
    13 PreRunner TRD Sport
    Bilstein 6112(650lb Springs)/5160, 3 leaf add a leaf, JBA STD UCA, Superbumps F&R, AEM air filter, Blackwidow widowmaker muffler, ultimate headlight mod, ultimate fog light mod, Work S1HC, ECGS 3rd member ( Truetrac, 4.30 gears), Bamf behind the grille bracket( 3x auxbeam 90w), Aux fusebox
  2. Oct 10, 2018 at 4:25 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Thats interesting, the Halogen Hella 500s are a very known and decent light. I had not seen that they came out with an LED version. Not much info on output, performance or light color. The forward facing LED does not allow for the same beam control as something like the reflector based KC Pro-Sport G6s, which will be higher performing, but that may not matter for your application being a high beam light. The forward facing LED design of the Hellas will be thinner than an a reflector based design.
