hella retrofit frustration :(
Discussion in 'Lighting' started by tommelleo22, Mar 19, 2011.
  1. Mar 19, 2011 at 5:26 PM
    tommelleo22
    tommelleo22 [OP] Well-Known Member
    Joe
    New Castle, PA
    07 trd sport off road
    Yellow Fogs kicker cvr 10's alpine ivaw205 head unit, leveling kit
    ok so have the hella's drilled out and the bulbs expoxied in but am wondering how to hook them up without a relay. i hooked my hid heads up to my truck the h4 hi/lo with the relay but not sure how to hook up the hellas without the relay and harness any help?
  2. Mar 19, 2011 at 5:43 PM
    tommelleo22
    Joe
    New Castle, PA
    bumpity bump
  3. Mar 19, 2011 at 8:17 PM
    tommelleo22
    Joe
    New Castle, PA
  4. Mar 19, 2011 at 8:19 PM
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    not a clue but free bump for someone that may know.
    good luck
  5. Mar 19, 2011 at 9:51 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    I wish I knew what he was talking about... more details please. What model Hellas, what do you want them to do???
  6. Mar 19, 2011 at 11:10 PM
    JR616
    JR616 Well-Known Member
    JAMES
    SOCAL
    06 double cab prerunner
    use the stock hella relay, use the stock positive coming out of the relay to power the hid ballast
  7. Mar 19, 2011 at 11:12 PM
    99nmtaco
    99nmtaco Well-Known Member
    Patrick
    NM / VA
    (Sold) 99 Tacoma SR5, 2001 4 Runner
    3" lift -(Bilstein 5100 adjustable front with Eibach Coils, Bilstein 5100 rears w/ Deaver aal), B.A.M.F. BPV relocate bracket, Hella 500's with DDM Tuning HID mod, Aero 2525XL muffler "Freakin Sweet!", Custom built Linear Actuated Light Bar w 1-32" LED bar, Custom Rear Bumper with Swing Out Tire Carrier
    You are doing the hid mod to the hellas? I dont know that you can wire up HID lights without the relay. But I think if you were able to all you need to do is wire the switch to the positive on the battery with a fuse inbetween. ground the switch, ground the fogs and hook up a power wire from the switch straight to the lights. I dont know that that is safe to do tho. You may just want to go out and buy the relay I think there like $8?
  8. Mar 20, 2011 at 4:58 PM
    tommelleo22
    Joe
    New Castle, PA
    thanks JR that's what i did and sorry guys ya im doing the H.I.D. conversion to the Hella 500ff with the DDM 55w 4500k Kit
  9. Mar 21, 2011 at 11:23 AM
    outxider
    outxider Well-Known Member
    Sang
    Bay Area
    06 DCSB 4x4
    A few mods here and there and counting....
    It would be safe to run a relay. If you have the hella 500s, install per the instructions that are included with the kit. After that, you connect the positive wire from the ballast to hella fog harness, and ground the other. Everything is on a relay and properly grounded. If you need schematics, i can draw one up later for you.
  10. Mar 21, 2011 at 11:24 AM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    yeh.... you will want to run a relay with the hellas.
    I have converted 2 sets of 500s to HID, and if you don't have an extra relay, use the setup that comes with the hellas.
