Hella Sharptone DIY- Relay free, splice free, and no drilling!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nitori, May 19, 2016.
  1. Mar 24, 2018 at 6:59 PM
    #101
    huli467
    huli467 Turning Octopus
    Honolulu
    2015 TRD Sport 4x4
    The world is big...and I want to have a good look at it...before it gets dark - John Muir
    My stock horn wiring is all chopped up. Can someone detail or show me which wire you tapped into for the stock horn??
    ramirezja likes this.
  2. Apr 4, 2018 at 10:56 PM
    #102
    Man of Steel TRD
    Man of Steel TRD Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    Damn you @Nitori ! Now you went and made me order up some horns!! You down to help me install them?
    Nitori[QUOTED][OP] likes this.
  3. Apr 5, 2018 at 6:39 PM
    #103
    Nitori
    Nitori [OP] Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    You already know I am, but heck yeah! I've actually been kicking around the idea of finding a different spot to mount mine, or making a bracket of my own or something.
    Where do you think you are gonna mount yours?
  4. Apr 5, 2018 at 7:07 PM
    #104
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Probably just in the same spots as you did yours.
  5. Aug 6, 2018 at 5:42 AM
    #105
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
  6. Dec 1, 2018 at 5:56 PM
    #106
    Volksparts
    Volksparts AKA The Un"Official" Meso Taco
    Dave
    San Diego
    2017 Taco Runner
    I figured this is probably the best place to post my experience with my Sharptone and Supertone combo. I have ran it for the last month and yep it's pretty loud.
    https://youtu.be/D7hk8XSJHuE
    Just swapped out to Cadillac horns A, C, D and F today though.
  7. Apr 28, 2019 at 9:11 PM
    #107
    ramirezja
    ramirezja New Member
    jesse
    2018 Tacoma TRD Pro
    K&N air filter
    Thanks for the hi-res photos. I wanted to do the same set up as yours but i can not see how you did the wiring. From what I can tell the stock horns have a plug in. Did you use the stock wiring, or an aftermarket wire kit?
  8. Apr 28, 2019 at 9:22 PM
    #108
    CortezJB
    CortezJB Well-Known Member
    Juan
    San Francisco
    2017 Tacoma TRD Sport
    NADA
    all I did was extend the wires from the original harness, it was the simplest way!!
    max_o likes this.
  9. May 14, 2019 at 1:20 PM
    #109
    tspencerVA
    tspencerVA Well-Known Member
    Roanoke, VA
    2017 TRD OR DCSB
    TRD Pro Grill, ARE CX HD shell, step bars, Wet Okole, Husky Liners
    Anybody have any details on the Hella horns and how they may impact electronics?
    Getting some flakiness with this new JVC headunit install that involves the Supertone I have running on relay.
    Suspecting it is a poor ground wire job but looking for any input to see if these Hellas are prone to electrical disturbances on new vehicles
  10. May 15, 2019 at 8:04 PM
    #110
    max_o
    max_o Well-Known Member
    Colorado
    2018 Silver Sky DCSB OR
    I did the same using this as a guideline and it works great.
    I haven't had any issues yet with my install. No interference. But I also have mine wired to the factory harness.
  11. May 18, 2019 at 12:53 AM
    #111
    Arrogant Basturd
    Arrogant Basturd Active Member
    Albert
    2015 Black DCLB TRD Sport
    some one asked about relays, and if the supplied relays were good enough.
    this picture is from their brochure. it says the sharp tones run 42 watts each. and the super tones run 66 each.
    so a pair at 12 watts looks like 7 amps for a pair of sharp tones and 11 for a pair of super tones.
    i'm no electrician. but i think i did the math right. and if the supplied relays are rated 20amps. i think it can power a pair of either with no issues.
    https://www.hella.com/hella-sg/assets/media/Hella_Horns_Brochure_LoRes.pdf
    i'm thinking about getting a pair of sharp tones. worth it?
    PS. i've been running without my horn working properly for 6 months. clock spring/spiral cable must've been shorting out. horn only works in certain sweet spots when i turn the wheel. so i can never honk while i'm driving a straight line. just got it fixed today. so looking at upgrading horn. found this thread.
  12. Aug 17, 2019 at 4:31 PM
    #112
    Gmarq
    Gmarq Active Member
    Gerardo
    Fort Hood, TX (Killeen)
    '17 Super White Tacoma TRD Pro aka "dngr_panda"
    Yup, did the same here. Installed the Hella Sharp Tones in the stock locations. Used the original cables/connector for the OE horn and just made and added a grounding cable for both horns. Easy peasy.
    Shveet likes this.
  13. Sep 25, 2019 at 8:13 PM
    #113
    c808nner
    c808nner Well-Known Member
    Oahu
    1995 Tacoma 3.4 MT Extracab
    I just installed some sharptones on my 06 and reused the factory wiring and just made a ground that connects to where OP grounded. I feel as I must’ve done something wrong as they aren’t much louder than stock. Any guesses as to why they aren’t very loud?
    Edit: They don't sound very loud when testing, but when I stood infront of the truck and had someone else beep the horn it was noticeably louder
  14. Sep 26, 2019 at 2:39 AM
    #114
    COSTCOHOTDOG
    COSTCOHOTDOG Well-Known Member
    2018 TRD OR DCSB 6MT
    Try grounding it straight to the negative battery terminal.
  15. Sep 26, 2019 at 3:26 AM
    #115
    c808nner
    Oahu
    Edited my post, just didn't sound very loud from behind them.
  16. Aug 24, 2021 at 7:13 PM
    #116
    timihendrix33
    timihendrix33 New Member
    Tim
    2013 Tacoma 4cl Manual Access Cab
    Thanks, this was super helpful!
