Hello first question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Prof.nohair, Oct 12, 2024.
  1. Oct 12, 2024 at 2:09 PM
    Prof.nohair
    Prof.nohair [OP] Member
    Jay
    21 Sr5 double cab Barcelona red
    Hey y’all
    I’m a proud happy owner of a 2021 gen3 I love the truck but definitely looking for a tuner/controller the throttle delay is brutal mostly. However would love opinions to know what everyone else runs.
    thanks
    Fye123 likes this.
  2. Oct 12, 2024 at 2:21 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    If you have an Auto, have you tried driving with the ECT button on? It will have a little more pep, but others like a tune. Welcome to TW.
    kahanabob and Prof.nohair[OP] like this.
  3. Oct 12, 2024 at 2:30 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
  4. Oct 12, 2024 at 3:05 PM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    OTT tune - problem solved.
    02tacotoy, wilbart, BeastBoy and 2 others like this.
  5. Oct 12, 2024 at 3:30 PM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
    Welcome to TW
    Prof.nohair[OP] likes this.
  6. Oct 12, 2024 at 4:03 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    welcome
    how was it when you test drove it before purchase?
    23MGM and BillF1564 like this.
  7. Oct 12, 2024 at 4:11 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Many enjoy driving as is (free)
    Many drive with ECT turned on full time (free)
    Many spend money on a custom tune OTT, etc. (not free-not cheap)
    Some waste money on Pedal Commanders
  8. Oct 12, 2024 at 4:40 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    A tune is what you seek. Do not waste a dollar on pedal controllers. Get your money worth
    drizzoh, boston23 and TacoManOne like this.
  9. Oct 12, 2024 at 5:23 PM
    Prof.nohair
    Jay
    Thanks everyone,
    I’ve yet to explore the etc button so I will definitely try it out tomorrow. I just got the truck so it’s all very new and my last was an 07 sport wrangler manual with roll up windows so all these fancy things are nice but a little overwhelming. I love the way it drives just when I step into it I can count a few seconds before anything happens. I’ll report back tomorrow after I play with ECT mode on. Thanks for all the warm welcomings I’m sure I’ll be here often
  10. Oct 12, 2024 at 7:02 PM
    Old goat1914
    Old goat1914 Well-Known Member
    Chicagoland, Indiana
    2016 TRD Sport DCLB 4x4
    My personal experience was that as time went by I learned to gradually press the gas peddle harder as the rpm went up. Hard to explain but there seemed to be a learning curve on how control the throttle. I no longer have a problem taking off quickly. Definitely has a problem with delay going no gas to all gas in less than 1/4 second. I would suggest you spend some more time if you could.
    soundman98 likes this.
  11. Oct 12, 2024 at 7:22 PM
    TA2016
    Oregon
    Here is the brochure for your 2021. Again welcome to TW.
    https://www.toyota.com/content/dam/toyota/brochures/pdf/2021/tacoma_ebrochure.pdf
    RIX TUX likes this.
  12. Oct 12, 2024 at 7:31 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    This forum is filled with fanatics who swear by OTT tunes. I don't get the hype. One gains 1-3 HP and the torque curve is barely shifted to the left. Like maybe 100 RPM.
    PRESS THE GAS PEDAL HARDER. USE THE ECT BUTTON.
  13. Oct 12, 2024 at 8:45 PM
    GaMGMTaco
    GaMGMTaco Well-Known Member
    Billy
    NE Georgia
    23’ MGM TRD OR DCSB 4x4
    If the throttle response is your only issue, save the money and press the pedal more/use ECT. @Old goat1914 is right about finessing the pedal as the rpm’s climb. If you don’t like the gear hunting then look into a tune. Best money I’ve spent so far going with the OTT tune. I couldn’t stand the gear hunting.
    kahanabob likes this.
  14. Oct 13, 2024 at 1:14 PM
    majpooper
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT has nothing to do with gaining HP. Also it does not void the warranty and does not effect emissions (just got my truck inspected no emissions issues). The excellent thing about OTT is they custom remap the truck For how and where you drive. Toyota maps the truck to get the best MPG data. The fact that an OTT fixes the anointing gear hunting issue is worth the price alone but it does way more than that. My truck that I use for off road and has 33s but does not have the added weight of a RTT and I live in a relatively flat area will be tuned much different than an over-lander who is weighted down in lives in a mountainous area vs a stock mall crawler daily driver and so on. You have to fill a lengthy questionnaire and like me will probably have a pretty in depth conversation with the tuner to get exactly what you would like/need.
    OTT remaps the computer settings - it:
    From OTT web site:
    https://overlandtailor.com/3gt-ott-custom-tuning
    "makes better use of low and mid range torgue"
    "custom upshift and downshift"
    "remapping of throttle curves"
    "adjust the transmission for the increased diameter"
    "Available sport mode in ECT for aggressive shifting maps"
  15. Oct 13, 2024 at 2:40 PM
    Prof.nohair
    Jay
    Well first off I want to thank everybody. This form is great so glad I joined you guys as I stated I came from a wrangler and the wrangler forums are nothing but a pissing contest and nobody helps anybody with actual answers so be here and actually have a conversation with you guys has been so nice. That being said that button makes such a difference driving to work today was much better. I think down the line. I will end up getting the tune for now until hopefully the economy turns around. I’ll have some spare change to get the tune.
    GaMGMTaco likes this.
  16. Oct 13, 2024 at 4:32 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Assume you mean the ECT button.
    I drive with mine on all the time'
    I got plug and play mod now the ECT comes on when i start the truck. I hve to push the button to go back to normal "sucks" mode
    Good when going places and making many stops.
  17. Oct 13, 2024 at 4:41 PM
    Azrael's Gaze
    Azrael's Gaze Well-Known Member
    Steve-O
    Springfield, Oregon
    2022 Black Tacoma TRD Offroad
    Ect mode. Or its a placebo im tricking myself with
  18. Oct 13, 2024 at 5:08 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    +1. my personal experience is that the factory preset throttle curve is ideally suited for grandma's going to church. after thrashing on it for a few weeks, the truck came to the realization that i am neither a grandma, or am i going to church, and we mostly get along now.
    i never got into ect mode. too many button presses when getting in. if i need more of any gear, i'm grabbing manual mode instead. trick is to shift before letting off to force the next gear change.
    Prof.nohair[OP] and GaMGMTaco like this.
  19. Oct 13, 2024 at 5:16 PM
    Prof.nohair
    Jay
    I just got rid of a manual transmission wrangler so I’m kinda iffy about the S mode cause I know it won’t be the same.
  20. Oct 13, 2024 at 6:40 PM
    soundman98
    NW Indiana
    it's not. but it is. the main advantage is that it holds up to the selected gear. so '4' means that coming to a stop it will cycle through starting at 1st, and work it's way up to 4th. it also doesn't allow you to over-rev(angry dash beeps), and you don't need to rev-match(benefit of the automatic clutches).
    it's no substitute for a 3rd pedal, but it's an alternative that allows more control. boring highway/around town, i'll keep it in normal autotragic mode. but if i want the 'gloves off' for any reason, it's in s-mode, and i control every gear.
    just don't hit redline. the rev hang/safety will literally cut the truck off for 5 seconds...
