Hello from HI
Discussion in 'New Members' started by SUPERBANG, Dec 5, 2017.
  1. Dec 5, 2017 at 9:36 PM
    SUPERBANG
    SUPERBANG [OP] Member
    Maui ,HI
    1996 Tacoma 3.4 V6 4x4
    Yo from HI maui! Newbie to the forums. I got a 96 3.4 4x4 manual 190000 miles I just picked up from my friend. It might need a engine rebuild or a new clutch/TO bearing and flywheel. It's making a noticeable tapping noise from the passenger side of the engine and louder if u go underneath. It's not that loud but its enough to question it. I just did a valve cover gasket replacement, new alternator and oil change. Not sure if I caused the tapping or if the truck was already tapping. But I'll do some research here. I use to be active in srtforums.com so I kind of know my way around a forum.
    Cativelense likes this.
  2. Dec 5, 2017 at 9:41 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome!
  3. Dec 5, 2017 at 9:46 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Welcome to the Madhouse!!!
    :worthless:
    The tapping noise is coming from a midget stuck in your Glove Box. Toyota just puts them In Their for the fun it.
    Key-Rei likes this.
  4. Dec 5, 2017 at 9:46 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    :wave:
    Just make sure you take it easy till 200k, that 3.4 is still in it's break in period.
    Welcome!
  5. Dec 5, 2017 at 9:49 PM
    eon_blue
    Azusa, CA
    Does the "tapping" sound like a cricket chirping? Does it go away when the clutch is pressed? If so then it's your throwout bearing, nothing wrong with the engine. The TOB is a simple and cheap part but it's a pain to replace, basically have to do a clutch job so most people just replace the clutch while they're at it. Welcome :)
  6. Dec 5, 2017 at 10:00 PM
    SUPERBANG
    Maui ,HI
    Tapping is always there even with clutch pressed in. Noticeable during idle when warmed up. Cold start tapping isn't there. When rpms go up, can't really hear I'm thinking because normal engine noise floods tapping.
  7. Dec 6, 2017 at 4:58 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
  8. Dec 6, 2017 at 6:39 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Welcome from TX!:hattip:
  9. Dec 6, 2017 at 7:12 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
  10. Dec 6, 2017 at 8:51 AM
    SUPERBANG
    Maui ,HI
