hello i have a question about wheel spacers.
Discussion in 'New Members' started by trvnscr, Mar 19, 2017.
  1. Mar 19, 2017 at 11:10 AM
    trvnscr
    trvnscr [OP] Member
    Hi I am new to the Tacoma World and I need some info on wheel spacers. I have a 2007 Tacoma SR5 Prerunner with a 3" leveling kit. do I need wheel spacers in order to fit 33x12.50r20 on my truck? if so what size spacer would I need?
  2. Mar 19, 2017 at 7:49 PM
    PreRunnerMan
    PreRunnerMan Well-Known Member
    Alex
    SoCal, Whittier
    White 2010 PreRunner SR5
    ADS Coilovers LR UCAs Bilstein shocks in the rear Dakar Leaf Pack CMC 287/70/17 BFG K02s
    What type of wheels are you running and what are the specs in regards to be offset and backspacing?
    ODNAREM and Ariyan like this.
  3. Mar 21, 2017 at 11:44 PM
    trvnscr
    trvnscr [OP] Member
    sorry it took me awhile to answer. The wheels are ultra motorsport Gauntlets 20x9. The offset is 18mm.
  4. Mar 21, 2017 at 11:45 PM
    PreRunnerMan
    Alex
    SoCal, Whittier
    What about backspacing?
  5. Mar 21, 2017 at 11:49 PM
    trvnscr
    trvnscr [OP] Member
    to be honest I don't know how to find that
  6. Mar 21, 2017 at 11:52 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
  7. Mar 21, 2017 at 11:54 PM
    trvnscr
    trvnscr [OP] Member
    i found it on TireRack.com it says it is 5.67"
  8. Mar 21, 2017 at 11:55 PM
    trvnscr
    trvnscr [OP] Member
    Thanks Windsor
  9. Mar 22, 2017 at 12:03 AM
    PreRunnerMan
    Alex
    SoCal, Whittier
    Ya you probably are going to need a wheel spacer avoid rubbing the UCA, and with that size tire you are aware of the amount of trimming your going to have to do and possibly a CMC
  10. Mar 22, 2017 at 12:06 AM
    trvnscr
    trvnscr [OP] Member
    yeah I know about the trimming but what is a CMC
  11. Mar 22, 2017 at 12:07 AM
    trvnscr
    trvnscr [OP] Member
    I figured it out
  12. Mar 22, 2017 at 12:09 AM
    PreRunnerMan
    Alex
    SoCal, Whittier
    Cab Mount Chop, basically chops part of the cab mount off and you have a new plate welded in, it gives more clearance in the fender on turns. I'm running an OME lift on 285/75/17 and I had to do the CMC.
  13. Mar 22, 2017 at 12:19 AM
    trvnscr
    trvnscr [OP] Member
    oh ok it seems like something I could do myself huh? Would it bother my tires if I don't off-road?
  14. Mar 22, 2017 at 12:26 AM
    PreRunnerMan
    Alex
    SoCal, Whittier
    It all depends, on how bad it is at full lock and any sort of flex in the suspension. It's almost a for sure that you will have trim some of the fender since with the wheel spacers you are pushing the tires out in order to clear the UCAs. And when trying to turn you may hit the fender well. I had a local member to me do the CMC for me since I do not know how to weld.
  15. Mar 22, 2017 at 12:28 AM
    trvnscr
    trvnscr [OP] Member
    nice your lucky cause I don't know how to weld I was going to cut it and and take it to get welded. what size do you think I would need with the wheel spacer? I was thinking 1.50"
  16. Mar 22, 2017 at 12:31 AM
    PreRunnerMan
    Alex
    SoCal, Whittier
    Ya or 1.25" might even work, trying finding any local members to you that can help you with the CMC, if you have to do it
  17. Mar 22, 2017 at 12:33 AM
    trvnscr
    trvnscr [OP] Member
    yeah I should. how would I find someone in the Houston, TX area?
  18. Mar 22, 2017 at 12:34 AM
    trvnscr
    trvnscr [OP] Member
    I might try 1.25". That was my first choice.
  19. Mar 22, 2017 at 12:36 AM
    PreRunnerMan
    Alex
    SoCal, Whittier
    https://www.tacomaworld.com/forums/texas.46/
    That's the link to the Texas regional thread, you can look to see if there is a Houston thread, or you can create a thread there for help with a CMC to see if anyone in the Houston area is able to help you.
  20. Mar 22, 2017 at 12:37 AM
    trvnscr
    trvnscr [OP] Member
    Thanks PreRunnerMan. You helped out a lot. I am going to look on that thread.
