Hello I'm Beatriz L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beatriz, Jul 15, 2024.
  1. Jul 15, 2024 at 12:24 PM
    Beatriz
    Beatriz [OP] New Member
    Beatriz
    2015 Toyota Tacoma Limited
    I'm an ower of a Toyota Tacoma Limited 2015.
    I love my truck .
    It only has 180kmls on it.
    In mint condition.
    I'm finding that ,as I'm aging I need to bring it down a couple of inches or 3 lol
    What's your intake in doing it?
    Thank you
    ToyoTaco25 and HondaGM like this.
  2. Jul 15, 2024 at 1:01 PM
    NOLAN_3G4R
    NOLAN_3G4R Active Member
    NOLAN
    WNC
    '87 4RUNNER/'97 TACO/'97 4RUNNER
    MOSTLY STOCK
    Hello Beatriz, welcome to the forum! Being that your truck is a "limited" it might be a challenge to drop. is yours a 4x4? Generally, people lower the 5-lug, 2wd models. Same body, different chassis.
    HondaGM likes this.
  3. Jul 15, 2024 at 1:34 PM
    Beatriz
    Beatriz
    Hello Nolan,
    Yes , is mine.
    I thought that I just need different size of Rims and Wheels .
    My Truck is beautiful, however due to its high 4" higher it winds as I drive over 90 Kls per hour.
    What should I do.
    I know nothing about this and don't want to take advantage of I guess
    HondaGM likes this.
  4. Jul 15, 2024 at 1:37 PM
    kwanjangnihm
    kwanjangnihm Timeout Terminator
    Jeff
    Central Florida
    13 DCLB TRD SP PR OTT
    "If it ain't a longbed it ain't shit! :)
    Welcome to TW Beatriz!
    Post some pics of your 15 limited. :thumbsup:
    HondaGM likes this.
  5. Jul 15, 2024 at 1:40 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Is the truck stock, or does it have an aftermarket lift?
    And, thinking out the box, have you considered putting retracting steps on it (look at Amp Powersteps)?
    HondaGM and wilcam47 like this.
  6. Jul 15, 2024 at 1:40 PM
    NOLAN_3G4R
    NOLAN
    WNC
    MOSTLY STOCK
    Smaller wheels/tires would absolutely be a step in the right direction. Just have to make sure you dont go TOO SMALL or you could run into fitment issues. The other option of course, would be modifying/upgrading your suspension, or even adding a step to make it a bit easier to climb in.
    HondaGM likes this.
  7. Jul 15, 2024 at 2:57 PM
    busychild
    busychild Well-Known Member
    Alberta, Canada
    14 DCSB TRD
    TRD Exhaust, TRD Sport Short Shifter, Skid Plate, K&N Intake, Bakflip G2 Cover, Husky Liners, Falken Wildpeak ATW3. Alpine ILX-259, JL Stealthbox w 10TW3, JL XD600, 2x JL 650-x (front and rear doors), Subaru Kicker Tweeters, Motegi Traillite 17x8.5, Westin Side Steps .
    better side steps? something that helps ease of access maybe something extra grab handles to get in and out?
    HondaGM likes this.
  8. Jul 16, 2024 at 10:20 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Smaller wheels and smaller tire diameters will cause an offset with speedometer. Same issue when people go with a larger that stock tire diameter. She would need to get a speedo calibrator. It'll also look really weird, but that's personal preference.
    I second the motion for bed steps if you don't already have a set. You might be able to lower the front somewhat, but the rears use leafsprings and have bump stops. Maybe look into an airbag suspension? Those are adjustable, but I don't know much about them. I do know they're quite expensive and a complicated install.
    GilbertOz and HondaGM like this.
  9. Jul 16, 2024 at 10:22 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW BB....
  10. Jul 16, 2024 at 10:50 AM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    SOS Performance makes a lowering kit for prerunners . Would also recomend getting shorter bump stops for front
    Yours lifted so wont work
  11. Jul 16, 2024 at 10:54 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I bought a 5-lug in part to have a lower step-in and load-in height as well as to keep the roof rack within reach. It has spring-under rear leafs in addition to the small 215/70R/15 tires so it’s considerably lower than any of the 6-lug models while still being stock. You can put smaller wheels/tires on yours but it will look a bit odd if the suspension isn’t lowered some to keep the wheels in the wells. The other difference is the differential is geared for the size wheels the truck is sold with which why so many regear their trucks when they get bigger tires. You will find yourself shifting sooner in every gear and not going as fast at the same rpm even though you can accelerate a bit quicker. It might tend to spin the tires if you have a heavy foot or the traction is suspect.
    Yes, you can put smaller wheels on it but there will be noticeable consequences you should be aware of even if you’re okay with them.
  12. Jul 16, 2024 at 11:13 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    It sounds like your truck is modified. We'd need to know what modifications were done to help. Start off with a picture of the entire truck from the side, then pictures of the front suspension and rear suspension. Picture of the front shock/coilover to be a little more specific, and the rear shock and leaf springs, including where the leaf springs touch the axle, that way we can see if there is a lift block, or taller leaf springs. This would be a good start for folks to give you better answers.
    Oh yeah, and tire size.
    O'DubhGhaill likes this.
  13. Jul 16, 2024 at 11:28 AM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Oh yours is lifted.
    What He said ^
