Hello, Im Will aka wilsterx owner of a 2012 silver v6 rear wheel double cab Taco.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wilterx, Feb 7, 2018.
  1. Feb 7, 2018 at 5:34 PM
    Wilterx
    Wilterx [OP] New Member
    William
    2012 two wheel taco v6
    I happened upon a short thread on here while searching for a possible solution for the dreaded intake clattering noises. And I finally fixed. Rubber washers on the 10 mil bolt which secures pwm vac switch valve. Wooohooo!
    Alexely999, tcBob and Justanotherhemi like this.
  2. Feb 7, 2018 at 5:40 PM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    Welcome to Tacoma World! There is an unlimited amout of information that is extremly helpful. Enjoy this great forum!
    Alexely999 and tcBob like this.
  3. Feb 8, 2018 at 2:03 AM
    airsavage
    airsavage Well-Known Member
    Butch
    2020 Tundra Sport 4x4 MGM, 2000 Prerunner
    Welcome aboard. Enjoy the truck and the TW threads.
  4. Feb 8, 2018 at 8:07 AM
    Blandino
    Blandino Well-Known Member
    Damien
    2011 Double Cab Tacoma
    Whistle Tip Exhaust
    Your alias provided in the thread title doesn't match your forum handle. Something shifty for sure about this one.... We're onto you, pal.
    Alexely999 likes this.
  5. Feb 8, 2018 at 8:11 AM
    Pigpen
    Dan
    Northwest Montana
    Multiple personalities
