Hello, just joined. Looking to learn some things.
Discussion in 'New Members' started by Mudfish OU812, Dec 5, 2016.
  1. Dec 5, 2016 at 8:48 PM
    Mudfish OU812
    Mudfish OU812 [OP] New Member
    '08 Tacoma
    Just joined while looking for some input on an issue I'm having. Will check search first but if no luck I will get back with everyone. Cheers
    Vibration/Humming noise around 40-50 mph. Changed U-joints out, still have it. U-joint next to transmission was bad, one race cap had zero bearing in it and worn shaft down to a half moon shape. After changing all U-joints, took care of heavy vibration but still have vibration/humming noise at 40-50 mph. When removing drive shaft, transmission output shaft was loose and could move it around with just fingers. Are the trans bearing/races worn out? Should trans output shaft be loose like this? Had a little trans fluid leak out when removing drive shaft.
  2. Dec 5, 2016 at 8:50 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Ears are perked.
    Welcome
  3. Dec 5, 2016 at 8:51 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Lol if you're going to make a thread you might as well say what the problem is. Now you're going to have a bunch of people wanting to know what the issue is. Hope you get it sorted out.
    inwood customs likes this.
  4. Dec 6, 2016 at 8:14 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    :notsure::popcorn:
    ChadsPride likes this.
