hello, my name is Rickey 70 years young with first Tacoma 2005
Discussion in 'New Members' started by Rickeyb, Jul 23, 2024.
  1. Jul 23, 2024 at 7:19 AM
    Rickeyb
    Rickeyb [OP] New Member
    Rickey
    2005 toyota tacoma 2wd automatic
    none
    bought the truck with 177000 miles , have not driven 5k and the main drive shaft carrier fell apart. working on the ground and not familiar with these trucks. not sure how the drive shaft comes out of the transmission. I did see some video on marking and removing 14mm nuts but before i screw it up just maybe some kind soul can inform me on the transmission end removal.
    does it slip out of the transmission and will oil leak out? I don't have a garage to work in. just looking for some advice .
    thanks for any and all help.. I was a technical trainer and have good mechanical skills until i was thrown out during the virus. now living like most on SS. so cost for someone else to do it is not an option
    mtip, jwctaco, HondaGM and 6 others like this.
  2. Jul 23, 2024 at 7:22 AM
    Xero
    Xero Well-Known Member
    18 Tacoma TRD Off Road, 22 4R, 08 4R
    18 Tacoma TRD off road OME BP51 front Fox 2.0 Resi rear OME Dakar Meduim Yoko G006 325/75r16 Black Rhino stadium wheels Cali raised ditch light brackets Baja Designs S1 pods Baja Designs Squadron SAE fogs Prinsu Cab rack TRD Pro grille AVS rain guards Backwoods adventure mods hi-lite bumper BL Apex 12k winch Dobinsons 4x4 snorkel Sy-clone prefilter ARB rear diff breather relocation RRW rock sliders RCI full skids At the helm bed stiffeners lil b LCA skids Warfab Phantom rear bumper Warfab tie rod sleeves C4 fender liners Dirt king UCA Duro bump stops
    Welcome to TW!
    Hopefully someone will be able to come along and help.
    HondaGM and buckhuntin-tacoma like this.
  3. Jul 23, 2024 at 7:28 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    On 2wd trucks the driveshaft yoke should slide out of the transmission, a small bit of transmission fluid may leak out when you pull it so have a catch pan under it.
    The rear yoke is bolted to the pinion flange with 4 bolts and nuts.
    Take note of how far in the transmission it is so you can reinstall the carrier bearing in the same position.
  4. Jul 23, 2024 at 7:56 AM
    Rickeyb
    Rickey
    none
    great info, the tube must be splined, does it have a specific reentry position ?
    thanks again, working blind is not fun especially when it's my only transportation.
    HondaGM likes this.
  5. Jul 23, 2024 at 8:03 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    As far as a specific rotation no but you do want it about the same depth so the seal is riding in the same spot to minimize the chance of leaks.
    Now the center yoke does need to go back in the same spot so the driveshaft yokes are all phased correctly so make sure to mark it before you separate it.
    mtip, HondaGM and Steves104x4 like this.
  6. Jul 23, 2024 at 9:10 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    HondaGM, lynyrd3 and rblalliance like this.
  7. Jul 23, 2024 at 9:13 AM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    Welcome :wave:
    HondaGM likes this.
  8. Jul 23, 2024 at 9:17 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    jwctaco, HondaGM and lynyrd3 like this.
  9. Jul 23, 2024 at 9:27 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Welcome to TW :hattip:
    Good luck with the repair
    HondaGM likes this.
  10. Jul 23, 2024 at 11:31 AM
    Rickeyb
    Rickey
    none
    Thanks for the welcome.. raining in NH so the work will wait.. I did spray all nuts and bolts ahead of loosining. need all the help i can get. Probably won't get this started until Thursday or Friday depending on the weather.
    Thanks again,
    HondaGM likes this.
  11. Jul 23, 2024 at 1:06 PM
    mit88
    mit88 Well-Known Member
    Planet earth
    Welcome, hope you found the better parts in your repairs.
    HondaGM likes this.
  12. Jul 25, 2024 at 7:58 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Here's the service info for the driveshaft.:thumbsup:
    HondaGM likes this.
  13. Jul 25, 2024 at 7:59 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…
    rblalliance likes this.
  14. Jul 26, 2024 at 4:03 AM
    Rickeyb
    Rickey
    none
    Thanks to DM93 for the service info. Going slow , sun shine and a good day to start.
  15. Jul 26, 2024 at 4:14 AM
    Rickeyb
    Rickey
    none
    I like the "You can do it " can you send him over .. last question for now as I see most of you have extensive knowledge on trucks and parts. The parts i see vary greatly in price. Probably all made in China .. Buying by cost has not worked in the past. Can someone recommend where i should buy the spiders and carrier from, your experience is better than my judgement. I don't want to do this twice. thanks again.happy Friday
  16. Jul 26, 2024 at 4:15 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Welcome to the TW
  17. Jul 26, 2024 at 6:28 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It's a Spicer driveshaft so I'd go with Spicer parts if you can get them.
