Hello Tacoma world . I'm new i'm chad. I Have a few inquires
Discussion in 'General Tacoma Talk' started by Firefighter Chad, May 27, 2023.
  1. May 27, 2023 at 12:08 AM
    Firefighter Chad
    Firefighter Chad [OP] New Member
    Chad
    Red TRD Sport Manuel
    Hello i have a 2006 TRD Sport Tacoma Manuel . I am wondering about good headlight bulbs to replace what i currently have . Witch i think are halogen . i'm hopping to get my lights Brighter. And if anyone could recammond me some good Bulbs. Also if anyone is selling or giving away im in need of a new shift knob as mine is torn . thats all for now and thanks :)
  2. May 27, 2023 at 12:30 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Chew likes this.
  3. May 27, 2023 at 12:45 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Welcome! Definitely a gigantic rabbit hole to climb down. If you're looking for LED replacements that don't involve replacing the housing, there are a couple of things to remember.
    Don't just run out and get the cheapest thing you see on Amazon. Quality bulbs are going to cost you. It's not just quality, but design. You'll want something that has an LED chip that closely matches the size and position of the filaments in your stock bulb. Otherwise you'll be throwing light and glare where you don't want it and, although your lights will seem brighter, you won't be actually getting anything more than better light immediately in front of you. Good ones will look more like a "blade" or flat-ish shape. Stay away from the ones that look triangular or any other shape like that.
    Chew likes this.
  4. May 29, 2023 at 3:39 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    I use Sylvania Silverstar ZXE’s, they are white, bright and have a nice cutoff, I also run them on my wife’s Honda cr-v.
  5. May 29, 2023 at 3:41 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
  6. Jul 2, 2023 at 5:04 PM
    Tiny's Taco
    Tiny's Taco The Wanderer
    Shenandoah Valley
    2018 Inferno TRD Sport
    That's a horrible idea. What time?
    All I have run in my halogens are the SilverStar Ultra. Nice white light, dramatically better than OEM.
