Hello to all my Yota brothers and sisters!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JoeySaturdaze, Jul 23, 2020.
  1. Jul 23, 2020 at 8:22 PM
    JoeySaturdaze
    JoeySaturdaze [OP] New Member
    Joey
    2007 Blue Tacoma
    Fenders
    I'm glad to be part of the Yota family.
    DavesTaco68, EdgemanVA and Hobbs like this.
  2. Jul 23, 2020 at 8:24 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Welcome to The Forum! :thumbsup:
    TnShooter likes this.
  3. Jul 23, 2020 at 8:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Welcome to TW
    :mudding:
    Hobbs likes this.
  4. Jul 23, 2020 at 8:28 PM
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    Welcome Joey
  5. Jul 23, 2020 at 8:51 PM
    JoeySaturdaze
    Joey
    2007 Blue Tacoma
    Fenders
    Quick question ya'll. I am debating on what rear end I should go with. I have a 2WD Taco crew cab. I have 4 1/2" bulge fiberglass fenders front and back. I am going with a long travel front end. I am running 35" tires. I am thinking of throwing in a Tundra or Sequoia rear for the width, strength, LS and disc brakes. I am also planning on throwing a shift kit and high RPM torque converter into the transmission. The diff would also get re-geard to 4:88's. Does anyone have suggestions?
  6. Jul 24, 2020 at 1:15 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Welcome aboard!
  7. Jul 24, 2020 at 6:56 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    welcome to TW. You can search on TW for the info you need such as tundra axle swap, lifts, gears, etc.
  8. Jul 24, 2020 at 7:07 AM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
  9. Jul 24, 2020 at 8:11 AM
    DR_CA68
    DR_CA68 Well-Known Member
    Dean
    San Jose
    08 TRD SPORT SHORTBED DC
    trying to keep stock
  10. Jul 24, 2020 at 8:17 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
  11. Jul 24, 2020 at 8:57 AM
    Muddinfun
    Muddinfun Well-Known Member
    If I were doing a spare no expense Taco build, I would put a Ford 9” rear axle in it. If you want to keep the ABS, weld Taco ends on the housing and have custom chromoly Taco axles made with splines to fit the 9”. If you don’t care about ABS, just buy Ford 9” chromoly axles with 6 lug wheel bolt pattern. It doesn’t matter if you go with 28 spline or 31 spline Ford 9”. A Taco motor is not going to break either.
    Some people put a Dana 60 rear axle in. The only advantage over the 9” that I see to that, is the Tim Taylor bragging rights. “Oh! He’s got a Dana 60”.
    The disadvantages to the 60 are weight and ground clearance.
    Jimmyh likes this.
  12. Jul 24, 2020 at 3:22 PM
    JoeySaturdaze
    Joey
    2007 Blue Tacoma
    Fenders
    Oh snap!!! Thank you so much. I will go with the 9" I had a feeling there was a solution.
    Muddinfun likes this.
  13. Jul 24, 2020 at 9:07 PM
    Muddinfun
    There is huge support for the Ford 9”. You can get anything you want for it. Detroit locker, air locker, spool, whatever. Many people use them in very high horsepower drag cars. The big advantage of it is that there is a 3rd pinion bearing that keeps the ring and pinion from separating apart under heavy load. Like I mentioned above, decide if you want to retain ABS or not and proceed accordingly. Then talk to the people that make chromoly axles and get things worked out.
    The 28 spline axles were in cars. The 31 spline axles were in 1/2 ton trucks. I run a 31 spline axle in in a ‘78 Ford with a 460 and I beat the snot out of it and it holds up, even with stock axle shafts. Chromoly axles are stronger than you need, but the key thing is they will build them for you to your specs.
  14. Jul 24, 2020 at 9:26 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Welcome to the Forum :thumbsup:
    Got any pics of your Tacoma?
