hello to all you toyota lovers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by davehurx, Jan 28, 2021.
  1. Jan 28, 2021 at 1:23 PM
    davehurx
    davehurx [OP] New Member
    2015 Tacoma xspX
    none
    HI Im Dave.,and im a new (old)member here that needs some young help ..I have a 2015 tacoma that i bought new,i guess it must have come with wheel sensors in it----well the tires were very loud over the road so after 40,000 miles and with still good tread on them---i found a set of like new factory wheels and road tires that i bought....i found out that the new wheels and tires dont have any sensors in them so -the dash light wont shut off...whats the best way for an old guy to get it to go out----please be kind lol
  2. Jan 28, 2021 at 1:26 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    I've installed these in three vehicles, a 4Runner, a Tacoma, and a Mustang. They work great, are easily programmable, and are far cheaper than OEM.
    https://www.pdqtpms.com/
  3. Jan 28, 2021 at 1:27 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Have the old sensors moved to the new wheels
  4. Jan 28, 2021 at 1:30 PM
    Fullboogie
    Dave
    Houston
    That would work too - but they're 6 years old at this point so maybe new ones would be a good investment.
  5. Jan 28, 2021 at 1:33 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Take it to Discount tire and have new ones installed. You have a nice truck, keep it that way.
    smokier likes this.
  6. Jan 28, 2021 at 1:59 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    My 2010 had one of the sensors fail... The warning light came on as if one tire was low on air. Checked all tires and air was fine. Turns out the battery in them only lasts so long! So far, just one of the 4 sensors needed a new battery... this was a couple years ago and Discount tire did it... not cheap. So if your truck is close to 9 years old, don't be surprised... and bring lots of money for battery replacements! LOL
  7. Jan 28, 2021 at 4:12 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Just replace all four on my daughter's Corolla from Rockauto. I think they were $40 each and another $20 or so to have them installed at Big-O's here in town. They can also program them.
    I'd have them installed if I were you.
  8. Jan 28, 2021 at 5:07 PM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    At least on the OEM/Denso/Pacific Industries sensors, the batteries aren't replaceable. The sensor must be replaced when the battery fails.
  9. Jan 28, 2021 at 7:22 PM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    I've not heard of any TPMS batteries that were replaceable. Like said, get a complete set & have them installed & programmed to your Taco. Costs a little more but much simpler, a place like Discount Tire, They will furnish the new TPMS, install them, & reprogram all in one stop..... I was cheeeepo, bought a set of "Denso" TPMS off ebay, roughly $40, took to local Co-Op to get them installed, another $40, but they couldn't program them, then to a local Tire store to get them programmed, they didn't charge anything but I gave them a $20 & told them to get the shop guys pizza for lunch. Kind'f a pain in the azz but saved several bucks..... Decisions, Decisions.
  10. Jan 29, 2021 at 12:14 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    As others said Discount one stop at $60 a TPMS installed, old ones deleted and new ones added to ECM, and 6 year/72k warranty.
    Your choice as many posts on how to save and where to get them do a search on site.
  11. Jan 29, 2021 at 8:12 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Hi Dave. You must not be that old, ever drove a vehicle that didn't have a nanny that told you a tire was low? ;)
    A little piece of black tape will fix that light. Or so I've heard lol.
  12. Jan 29, 2021 at 9:15 PM
    Waasheem
    Waasheem
    2007 xrunner
    Don’t forget, the spare has a sensor in it too. At least my 07 xrunner does.
  13. Jan 30, 2021 at 2:46 PM
    David K
    My '10 Off Road TRD does not, fwiw.
