Hello
Discussion in 'New Members' started by Grit, Nov 19, 2011.
  1. Nov 19, 2011 at 10:59 AM
    Grit
    Grit [OP] Member
    Garrett
    Texas
    Hi! I'm currently a GM owner (I know, don't beat me to death:p) soon to be looking for a Tacoma. I had an older little Toyota truck back in the late 80's. I loved that little truck. I see they have increased in size since then. I don't really know the year I'm after and have joined the site to get a little more knowledge about the model years, body style changes, engines, ect.. My wife and I will probably end up buying used, so I'll research them carefully before making a purchase.
    I have noticed (depending on mileage) that the Tacoma's price hovers around the price of my own, if both are around the same year. Mine being a '05 Silverado Duramax Diesel Crew Cab 4x4 fully loaded, makes it kind of hard to swallow. :eek: But what that does tell me is that the little Toyota holds its value quite well, but is still an expensive little bugger.
    Anyway, thanks for having me and hope to chat with more of you soon.
    Garrett
  2. Nov 19, 2011 at 10:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome!
  3. Nov 19, 2011 at 11:02 AM
    Grit
    Grit [OP] Member
    Garrett
    Texas
    Thank you for the welcome!
  4. Nov 19, 2011 at 11:03 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Welcome to TW
  5. Nov 19, 2011 at 2:37 PM
    JRob33
    JRob33 Well-Known Member
    Josh
    Bossier City, LA
    '10 White Double Cab TRD Sport 4x4
    Welcome and good luck with your purchase!
  6. Nov 19, 2011 at 3:34 PM
    Grit
    Grit [OP] Member
    Garrett
    Texas
    Hey, thanks again for the welcome. I know us domestic guys are not well liked, but I'm trying to make that change over. It just may take a while! ;) I figure until then I can hob nob with some fine Tacoma owners. :eek:
  7. Nov 19, 2011 at 4:01 PM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    Welcome to TW! :wave: and good luck on your quest.
  8. Nov 19, 2011 at 4:03 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    welcome to tw!
  9. Nov 19, 2011 at 4:15 PM
    Banff2007Tacoma
    Banff2007Tacoma Well-Known Member
    Dave
    Alberta
    2007 Tacoma Black Sand Pearl TRD Offroad.
    GPS Navigation System, Old Man Emu complete lift with Dakar springs. Light Racing UCA's. BFG AT tires, KMC Enduro rims, Allpro E-locker guard. ARB Portable Air Compressor CKMP12. Backflip Tonneau Cover. Wet Okole seat covers.
    I was a GM owner before as well. Good luck with your purchase and you will not be disappointed. Welcome to TW.
  10. Nov 19, 2011 at 4:16 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Hi Garrett!
    The Tacoma got bigger in 2005... known as the Second Gen. Tacoma. The bed got deeper and wider in 2005, so the load carrying increased. My 2005 & 2010 5 ft. bed holds as much cargo as my 2001's 6 ft. bed held.
    There is a regular cab, an 'Access Cab', and a Double Cab (4 door). The DC (double cab) has a standard 5 ft. bed (overall length close to Access Cab with the 6' bed)... or an optional 6 ft. 'long bed'... but that makes the truck longer than all the other models.
    If 4WD is your desire, then you got it available with all Tacomas. Only the OFF ROAD TRD has a locking rear differential. All other Tacoma models (SPORT TRD, SR-5, LIMITED, Base) have the same traction choices available... An exception is the SPORT TRD from 2005 to 2008 which had a mechanical limited slip rear differential.
    In 2009, all Tacomas were fitted with TRAC (limited slip) and VSC (vehicle stability control). Only the OFF ROAD TRD since '09 has ACTIVE TRACTION CONTROL (A-TRAC) which is an advanced super-limited slip that works in low range 4WD and provided the traction very close to have front and rear locking differentials. So, if you are thinking of doing some intense four wheeling, do consider the Off Road 4WD Tacoma. The only way to have more traction than A-TRAC and your rear locker is to add an after-market front locker... The high cost of a front locker may not justify the addition if you already have A-TRAC or even just the rear locker.
    Good luck and welcome to Tacoma World...!
  11. Nov 19, 2011 at 4:20 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Not true at all! Mine is domestic, came from Fremont CA!
    But not to worry about not being well liked. Those other domestic trucks are what made a lot of us turn to our Toyotas. :D
    (Even though my Ram was one sweet vehicle that never gave me an inkling of an issue. I miss my Ram. :( )
  12. Nov 19, 2011 at 4:22 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Welcome and good luck.
  13. Nov 19, 2011 at 5:35 PM
    Grit
    Grit [OP] Member
    Garrett
    Texas
    David, thanks for that information. It may take me a while to soak that info in, as I don't know many of the features just yet, but I'm sure I will get it figured out. Thanks for taking the time to explain some of that to me and I will use it to refer back to when doing my research. Thanks!
    babytruck, I must say, you have a good point there. I never really thought about it that way. I don't feel so bad now! :D
    To be truthful, I really haven't had much trouble with the truck I have, or at least not until the other day. Thank goodness it was something I could fix on my own without getting raped by the stealership. If I can do it myself, I'm all over it. Unfortunately, I'm getting at an age where I don't enjoy laying on my back looking up at the underside of an engine. Or for that matter, climbing on top of one (like my truck). Which is all the more reason I'll appreciate a Tacoma. ;)
    We had originally purchased the truck to do some RVing when my wife retires, but we decided that it wasn't in our best interest to do so. I think my wife realized traveling in that manner could get quite expensive, and we really need to watch our pennies so not to come up short before drawing ssi. It's a good thing I'm quite a few years younger than her. I can always make that extra money.
    Anyway, that's the reason we'll be looking for something smaller. I have always loved the little Tacoma's. I've always admired the Tacoma's and look forward to purchasing one in the future.
    Hey, and thanks again for the welcomes. Lots of really nice folks here.
  14. Nov 19, 2011 at 5:48 PM
    babytruck
    NorCal
    They aren't that little, my friend! Stock height.
  15. Nov 19, 2011 at 5:55 PM
    Grit
    Grit [OP] Member
    Garrett
    Texas
    Yes, thanks for reminding me. :eek:
  16. Nov 19, 2011 at 6:02 PM
    Grit
    Grit [OP] Member
    Garrett
    Texas
    Actually, I think the bigger size is good in a way. Vehicles have gotten bigger, taller and heavier over the years. If it was still a dinky truck, your life could be at risk -- seriously. :eek: I think I'd rather be in something with a little heft. After all, that is what I'm used to... ;)
    I sure do miss that early model Toyota I had, though. :(
  17. Nov 19, 2011 at 6:19 PM
    T-Rex266
    T-Rex266 T-Rex Moderator
    Welcome from CO. I have an 09 TRD Off Road an love it! Expensive, yes but Tacos retain their values.
    This sight will provide u with a lot of new knowledge and insight. Check out the DIY write up thread. Lots of great things you can do!
  18. Nov 20, 2011 at 12:42 AM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
  19. Nov 21, 2011 at 9:35 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    [​IMG]Welcome to TW from Sparks, NV[​IMG]
