Hells revenge trip report
Discussion in 'Moab' started by WarFab Armor, May 30, 2018.
  1. May 30, 2018 at 10:27 PM
    WarFab Armor
    WarFab Armor [OP] www.warfabarmor.com Vendor
    Best-Slope, Colorado
    Pile of go slow parts.
    ran out to Moab for a quick day trip and ran my favorite - hells revenge. Solo trip so nothing crazy. Although up hells gate with no backup rig or spotter likely wasn’t the best choice. Slid over off the wall halfway up and with no locker meant I had to wiggle around a little to get the tires to bite. Either way, great trip as always. Can’t wait to get back.
    jubei, Jibbs, cidcoated4x4 and 4 others like this.
  2. May 30, 2018 at 10:38 PM
    WarFab Armor
    Even got to beat up my hitch skid I made. Worked like a charm!
    jubei, ColoradoTJ, quis23 and 5 others like this.
  3. Jul 26, 2018 at 5:02 PM
    jknubbles
    jknubbles Well-Known Member
    Jeff
    Why didn’t you just wait at the starting point and jump in with a group?
    Nice pics though man! Did you bypass or beef your way up the crux of the route?
  4. Jul 26, 2018 at 5:09 PM
    WarFab Armor
    I wanted to wheel solo on this run. If not one other. Out here again too. Ran the trail just fine. Even harder stuff this go around as well.
  5. Aug 23, 2018 at 10:47 AM
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    What are your thoughts on the hitch skid? Well worth having along? I have thought of getting the one made by Skidmark4x4. The one on your truck looks to be out of the way and relatively low profile.
  6. Aug 23, 2018 at 2:33 PM
    WarFab Armor
    I love it. Especially in Moab. Yes you’ll hit it more than if you had nothing. However it keeps the backend off of stuff and slides instead of catching. I made it to sit as tight as possible so it wouldn’t catch as much. A lot are made to fit loose and easy, that’s why I started to build it.
  7. Aug 23, 2018 at 2:36 PM
    WarFab Armor
  8. Sep 2, 2018 at 10:48 PM
    xGRIMEYx
    xGRIMEYx Go follow #RheaTheGray on IG!
    RheaTheGray
    fort worth, tx
    17’ TRD PRO
    Fox 2.5s w/resi SSO slimline front bumper OVTune 1.05 SCS ray10s 285/75/17 KO2s JL Audio C5s Rigid Industries ditch lights & light bar Warn VR8-S gen II RCI rear bumper 5.29 nitro gears UpTopOverland roof rack TJM sliders ARB twin compressor bed mounted
    i’m going to moab for the first time later this month, without a hitch skid like this will my bumper be in danger or will i just grind the hitch at bit with no body damage to the actual rear bumper?
  9. Sep 3, 2018 at 4:43 PM
    WarFab Armor
    Depends on the trails you run. But your likelihood of dragging the bumper caps, especially on the corners is pretty high.
  10. Sep 3, 2018 at 4:48 PM
    EatSleepTacos
    Randy
    Hampton Roads, VA
    4x4 2005 SR5 AC 6MT
    I used to leave this in my hitch while offroad with no shackle, and I always drug it. That was exactly my plan though because I'd rather drag this than anything else. Also doubles as a safe recovery point. Would definitely recommend.
    https://www.amazon.com/Smittybilt-2...8383&sr=8-1&keywords=hitch+shackle+smittybilt
    You can see at the end of this shitty video how hard I drag it. It works great.
    https://www.youtube.com/watch?v=5R9Yc544ta0
    xGRIMEYx likes this.
  11. Sep 3, 2018 at 10:25 PM
    xGRIMEYx
    RheaTheGray
    fort worth, tx
    17’ TRD PRO
    hells revenge specifically? with the D-ring hitch suggested above will i be out of danger from damaging my bumper.
    are you able to avoid any obstacles on hells revenge, as in an alternate route? from all the vids I've been watching i don't want to try some of the obstacles seeing how green i am but i do want to check out the course and do some of it.
  12. Sep 3, 2018 at 10:30 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Lol no sliders ??
  13. Sep 3, 2018 at 10:41 PM
    ColoradoTJ
    ColoradoTJ Volunteer Moderator Moderator
    Colorado
    Looks like a great time to me.
    Still building the Spicy Jalapeño?
  14. Sep 4, 2018 at 3:16 PM
    WarFab Armor
    At that time no. Ground clearance for hells revenge is more than adequate. Has some I am testing on it currently. Second version being designed.
  15. Sep 4, 2018 at 3:17 PM
    WarFab Armor
    Hahaha. No the jalapeño is gone. It traded hands a few times and new owner is doing a killer job on redoing it the way it needed to be done. The taco has my focus right now but looking for my next build for sure.
    ColoradoTJ likes this.
  16. Sep 4, 2018 at 3:19 PM
    WarFab Armor
    You’re definitely going to drag ass on HR. You can get around pretty much any of the harder stuff (insert air quotes here) but there are a few climbs and dips, specifically as the trail nears the hot tubs that the length and overhang on the truck will all but force you to drag.
    The d ring mount above will save you some but it may hang you up as well since it’s not a smooth edge to slide on.
    HTH.
  17. Sep 4, 2018 at 3:22 PM
    EatSleepTacos
    Randy
    Hampton Roads, VA
    4x4 2005 SR5 AC 6MT
    The d ring holder shouldn’t hang him up. I’ve drug it A LOT with no issues. Part of it may be that the end is rounded.
  18. Sep 4, 2018 at 3:24 PM
    WarFab Armor
    I guess I looked at it wrong I thought it was a cornered edge. Yeah rounded should work great.
    EatSleepTacos likes this.
  19. Sep 6, 2018 at 4:09 PM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2018 TRD Off-Road, Super White.
    Bone Stock
    Is this one you purchased or built?
  20. Sep 6, 2018 at 4:11 PM
    WarFab Armor
    Built.
