Hellwig 981 EZ990
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Apr 29, 2012.
  1. Apr 29, 2012 at 1:37 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Petros "Peter" AGE: 44
    Miami, Florida
    DCSB 4.0 Auto PreRunn
    FRONT: OEM PreRunner coils, 5100's @ .85, MaxTrac Spindles, 1/4" Taco lean spacer. ground to fender base: LF & RF: 40"'s hub to fender base::::: LF & RF: 25"'s REAR: 2012 OEM 3/1 leafs, Wheelers 3 leaf AAL, 2" Tapered steel block. Bilstein F4-BE5-B110-T5 ground to fender base: LR & RR: 41"'s hub to fender base::::: LR & RR: 26"'s All mud flaps trimmed 4"'s shorter.
    Hello Forum,
    I've been looking into Hellwig helper springs & it looks like I will go with:[​IMG]
    I am looking for a slight lift AND firming up the rear. Anyone have any experience using these? Pics would be greatly appreciated also. My '08 Double Cab 4.0 Prerunner sits as follows (measured with a full tank of gas):
    l.f. 35.25 (thanks to ToyTec 1/4" spacer on top of l.f. strut)
    r.f. 35.25
    l.r. 36.25
    r.r. 36.00
    http://i1056.photobucket.com/albums/t379/TACRUN1/Photo0994-2.jpg
    I meaured them by centering the measuring tape on the center of the wheels & from the ground to the bottom of the fender trim. I hope that is the right way. My truck looks level & I think 2"'s is too much. If this Hellwig kit gives 1" of lift that would be awesome. I had the the EZ 550's for a week (I took them off because they had used ubolts) & it raised the rear end slightly. I like that the EZ 990 is almost as an AAL but not as high of a lift.
    Thanks:D
  2. Apr 29, 2012 at 8:54 PM
    TAC1
    Miami, Florida
    Also,
    Do I need to remove the OEM spring clamps?
    Do I open them so that the helper spring sits in them & then close them up?
    or
    Do the helper springs bolt over that also?:)
  3. Apr 26, 2013 at 4:15 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    I'm interested in these too, or the 550s. From the reading i've been doing, looks like they just bolt right on, no need to take anything off. I'm curious if these make the unloaded ride any harsher. From what I've read about the 550s, they don't.
    Did you end up installing them? How do you like them?
  4. Apr 27, 2013 at 4:29 AM
    TAC1
    Miami, Florida
    Hello bjboucher,
    I did buy the 550 and ran them for 5 months. I am currently running TRD springs with an AAL 3 leaf pack. When I had the 550 it gave me 3/4" of lift because I tightened them down to within a 1/2" from contacting the OEM leafs. I had the 2/1 OEM springs at the time.
    The only reason I don't have them anymore is because I wanted more lift. As for when I had them. Yes, the ride will be a little stiffer (atleast I noticed it) because you are adding 1/2 of a leaf to your current pack. I loved it. It handled nice. Also, it's a simple bolt on.
    But, do you have the 2/1 leaf pack or the 3/1 leaf pack? I am not sure but I think that the 3/1 leaf pack may interfere with the 550 because of the extra leaf clamp location. Check with the vendor before you buy them to make sure they will work. If you have the 2/1 the. No worries.
    Again, if it wasn't because I wanted to lift my truck I would still be running them n
    Hope this helps.
    Petros
  5. Apr 27, 2013 at 6:18 AM
    bjboucher
    Brad
    San Antonio, Texas
    Awesome, thanks!
    I do have the 3-1 leafs, so I'll do some looking around.
