Hellwig Sway Bars
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rob2.7Taco, Apr 19, 2011.
  1. Apr 19, 2011 at 12:25 AM
    Rob2.7Taco
    Rob2.7Taco [OP] Well-Known Member
    Rob
    Bay Area, CA
    2010 Tacoma Prerunner
  2. Apr 19, 2011 at 1:28 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    I've got that on my truck. Well worth it. Addaco also makes sways front and rear.
  3. Apr 19, 2011 at 3:54 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    I know toyota offers them under trd options for the tundra although I am not sure about tacoma
  4. Apr 19, 2011 at 4:52 AM
    ecrepeau
    ecrepeau Well-Known Member
  5. Apr 19, 2011 at 5:05 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Can't agree more about how the Hellwig bar helped handling. It's especially evident on highway where, before, semi's and crosswinds presented unwelcome adventures as they pushed my high-sitting, light-weight Tacoma all over the road.
    Installation was pretty easy... much easier if you drop the spare to make room while you work.
  6. Apr 19, 2011 at 6:09 PM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    Does it really help that much on the highway? I'm looking.for crosswind help. Bought Bilsteins but haven't installed them yet.
  7. Apr 19, 2011 at 6:17 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Hellwig is a great product.
    I had one on my 09 prerunner.
    When I did a lift the 2" AAL made the rear swaybar links too short.
    I was not able to move the bar due to parts in the way so if you are lifted be prepared to get longer links to keep it working.
    Good luck on the project.
  8. Apr 20, 2011 at 4:59 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    Absolutely, definitely YES! A rear sway bar helps tremendously with highway buffeting! It's almost amazing.
    What happens is the wind pushes you, you steer into it to keep from moving and the body leans. The lean changes the geometry of the front suspension which induces an 'under-steer' moment to the outside of the counter-steering radius, compounding the effect of the wind's push. So you dial even more steering correction to keep it going straight which makes it lean still a little more.
    All those interactive affects makes the steering vague as the wind speed changes so you can see how passing a big semi becomes a HUGE battle. The buffets come and go and reverse from left to right, making all those huge steering corrections hard to reverse to the other direction in order to keep going somewhat straight.
    I'm really not sure how much Billies help with that...but sway bars ARE the answer! Control the lean and you control the pulling and steering vagueness!
  9. Apr 20, 2011 at 5:39 AM
    ecrepeau
    By far the best upgrade you can do to the truck that will make it so much nicer to drive.
    Would put it above changing out the POS stock tires if I didn't live in the North East. Stock Dunlops and snow\ice = better have a damn good life insurance policy.
  10. Apr 20, 2011 at 9:30 AM
    Rob2.7Taco
    Rob
    Bay Area, CA
    Thanks for the help guys, i'll order the kit once my tsb gets done
  11. Apr 20, 2011 at 10:08 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I've have mine on for about 10 months now and I love it! The difference in driving was night and day after I installed it. Now I have to be careful when I hop into my F150 because I try to take turns at the same speed and I get WAY too much body roll haha.
  12. Apr 20, 2011 at 5:02 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Can we get a group buy going; pwees. Me wants.
  13. Apr 20, 2011 at 5:07 PM
    happyb
    happyb Well-Known Member
    Brandon
    on a beach in hawaii
    to my taste
    making a list
    can you explain a little bit more on why you need longer links for lifted trucks?
  14. Apr 21, 2011 at 4:30 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    I'm not lifted, but having put on a bar I think I see the situation..
    The bar is clamped to the axle tube on either side, about 1/2 way from pumpkin to spring perch, and the end links are attached to the frame, at the end of the bar's arms extending out from the axle. For best performance, the arms should be (nearly) parallel to the body of the truck. Lifting the truck extends the distance between the axle and the frame so the bar's arms would tilt way up, shortening the moment between the axle and the frame so it exerts less force against the outside wheel as the body leans. Longer end links lets you lower the bar arms back to optimal.
    Also, cause the bar arms are tilting way up the attach point has to move forward on the frame and apparently something else is there...so it won't fit!
  15. Apr 22, 2011 at 8:58 AM
    Rob2.7Taco
    Rob
    Bay Area, CA
    I'll contact Hellwig and start a group buy. I'm stoked to get one.
