HELP¡!¡! Installed winch, nearly burned my truck to the ground
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gunrunner269, May 7, 2019.
  1. May 7, 2019 at 6:47 PM
    Gunrunner269
    Gunrunner269 [OP] Well-Known Member
    I'm a professional mechanic & have a basic understanding of 12v electrical systems. But I'm a novice when it comes to winches & I'm not sure what's wrong.
    Smittybilt XRC 9500
    I installed the winch (brand new) with an ARB bumper on my truck about 4 months ago & finally had enough free time to wire up the solenoid tonight. However, when I connected the power & ground to the battery my engine bay turned into a smoke show.
    I made longer 2 awg leads for the solenoid so I could install it under the hood. All wires are hydraulically crimped & wrapped in heat shrink. I also tapped into the 3 leads for the wired controller inside the solenoid & ran leads into the cab for in cab controls. (note: these wires are not currently wired to anything)
    When I connected the wires to the battery it immediately sparked so hard that it began to melt the battery posts. The winch also immediately began spooling by itself. There was also smoke coming from the solenoid & winch, which I've identified as melting from each end of the small ground wire running from the solenoid to the winch.
    I rechecked & all the wiring appears to be correct. I'm stumped as to what could be the issue. I'm also exhausted & calling it quits for the night until I can get some rest.
    I also have a 500A battery isolator that will be wired between the battery & solenoid & controlled via an in cab switch to cut power to the winch when not in use, however it is not currently installed. I was running power straight to the battery to test the winch.
    Something wired backwards? Faulty solenoid?
    Wired as follows:
    Right, yellow
    Top, battery
    Bottom, red
    Left, black
    (Battery neg & small solenoid lead to winch case)
  2. May 7, 2019 at 7:11 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    BartMaster1234 likes this.
  3. May 7, 2019 at 7:54 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Oh my god it’s horrifying. Are you using four pin trailer wire? Nothing wrong with that, it’s just depending on the application it might not be rated high enough to carry current.
    It sounds to me like something is shorting somewhere or you have something switched.
    Also please please please get rid of those vampire splices. They are nothing but trouble.
  4. May 7, 2019 at 8:10 PM
    Gunrunner269
    Yeah, it's just some scrap trailer wiring. But it is just running to a in-out rocker switch in cab & is fused at 3A. In essence it's just an extension to the plug in controller. That's not the issue.
    I'm 99% sure everything is wired correctly between the solenoid, battery & winch but I'm super tired & don't have a diagram in front of me at the moment.
    My only guess is the solenoid is bad from the manufacturer. The positive wire sparked to the battery before even connecting the ground. Then when grounded it immediately began spooling & sparking & melting the small ground from the solenoid. My only guess is there's a bad internal ground.
    I have a digital multimeter if there's a way to test the solenoid.
    And yes, I know those taps suck. I was just using them to test my rocker switch before buttoning everything up. I'll solder & heat shrink them once everything is working correctly.
  5. May 7, 2019 at 8:18 PM
    soggyBottom
    soggyBottom Well-Known Member
    Set the multimeter to check for shorts. It should beep when one is found. I would check all the wires at this point. Also, what is the ohms reading of the winch?
  6. May 7, 2019 at 8:22 PM
    SportsmanJake
    SportsmanJake Well-Known Member
    VA
    2006 Tundra
    The winch solenoid is grounded as soon as you connect it to the winch because the winch is grounded through contact with the bumper.
    SR-71A and Wyoming09 like this.
  7. May 7, 2019 at 8:31 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Couple of months ago I bought a Comeup Seal Gen 2 9.5 RS winch.
    Brand new winch, simple wiring (nothing going to in-cab because I’ve got a wireless control) and similar thing happened to me - as soon as the battery was connected, the winch started autospooling in. It stopped thought everything was good, drove the truck on an errand and the winch spooled in while I was driving. Luckily I just had a zip tie on it and it snapped and didn’t have a shackle but the cone brake was heating up given the winch sucking down the synthetic line on the drum.
    Long story short, Comeup sent me a new solenoid and the winch has worked flawlessly since but was initially disconcerting considering I just spent $1300 on a premium winch.....
    Get a new solenoid.
  8. May 7, 2019 at 8:41 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Sounds like the solenoid is stuck closed. Might need to replace it, you can put a meter on it. It shouldn't have continuity until the 12V are applied
  9. May 7, 2019 at 8:54 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    If the solenoid were just stuck closed, then the winch would just run. But it wouldn't be smoking. You've got a dead short between your positive and negative battery terminals somewhere to give you insulation melting levels of current. Double check all of your wiring against the wiring diagram, seems like you've got sent heavy gauge wires swapped somewhere.
    12TRDTacoma likes this.
  10. May 8, 2019 at 1:24 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Simple to test if your solenoid is shorted Meter set to Ohms .
    This is where having the manufactures schematics is great for trouble shooting
    Comes down to wired wrong !!
    Damaged positive cable shorting
    Either A shorted solenoid or Winch!!
  11. May 8, 2019 at 12:08 PM
    Gunrunner269
    I'm fairly certain the solenoid is stuck closed and/or otherwise defective. It was also tossed around for the past few months as I moved to a new home, so it may have been damaged.
    Once I get home from work today I'm gonna recheck the wiring to make sure everything is correct & if so, test it with a multimeter & have it warrantied.
    The only thing I can think of is maybe the new 2 awg leads are too big & the lugs are making contact with the solenoid. It was a tight fit to get them installed. It came with 4 awg leads but I made new leads to relocate the solenoid into the engine bay & used 2 awg cables.
    cruiserguy likes this.
  12. May 8, 2019 at 12:10 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    In the last pic their is a bare spot on the blue wire. Maybe check all of them for bare spots
  13. May 8, 2019 at 12:15 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    good eye, looks like there is exposed copper on the right side of the blue wire as well
    mynewtoy[QUOTED] likes this.
  14. May 8, 2019 at 12:18 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Matter of fact I would disconnect all that and just try the solenoid normally
  15. May 8, 2019 at 12:20 PM
    Gunrunner269
    That's the ground wire that runs from the solenoid housing to the winch housing, & it's bare because it melted as soon as I connected the solenoid to the battery.
    cruiserguy and mynewtoy[QUOTED] like this.
  16. May 8, 2019 at 12:20 PM
    Gunrunner269
    It is wired normally. Those other 3 wires are leads for an in cab switch, but they are not hooked up to anything right now.
  17. May 8, 2019 at 2:15 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    But if the wires for the in cab switch are making contact with each other because of a bare spot or just something you missed. it could produce the symptoms your having.
    I’m not trying to be mean but it looks like a cluster fuck and a fire waiting to happen to me.
  18. May 8, 2019 at 2:18 PM
    Gunrunner269
    They are all capped off inside the cabin & touching nothing.
  19. May 8, 2019 at 2:25 PM
    0xDEADBEEF
    Do you have a wiring diagram you could post? I'm having a hard time imagining your wiring from the description above.
  20. May 8, 2019 at 2:30 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    There is a process to just jump a winch to the (a) battery. Your winch mfg can tell you how to do this. My mfg sent me to a online video, you can also do a web search how to jump a winch. This will take the truck (and its expensive electronics) out of the picture. If the winch runs nominally jumped out, then the problem is the wiring.
